I was thinking best case 15% cheaper than Turing, worst case, similar pricing.
+20% is really taking the ****.
Seems to me like we're gonna need all the vram we can get. QUOTE]
This makes me a little concerned as I'm currently waiting on a laptop with a 2060 to be delivered..
Ahhh very good point I hadn't considered thatYou can see all those when you fly over in MS Flight Sim
Had the same problem, big delay leading to TP.Is it my connection or is the site hard to post on?
By the end of this year (start of next) gamers will have the choice of buying a console and getting a 4k gaming experience for £1300 (including a TV that will more than likely be far superior to any monitor in the same price bracket) or buying a grapics card for £1300 (the rest of the system and monitor not included). The no brainer choice is to buy a console.
Yea and it can only go so far.They have been doing it for a while though. Have you not noticed how a Titan was "only" around £900ish and now is breaking £2000,etc??
They say Ampere is 20% more expensive model for model. The RTX2060 launched at $350/£350 so that means an RTX3060 is going to be over £420?? So that means its around the same price as an RTX2070 Super??
So an RTX3060 is going to almost cost the same as a PS5 on its own?? What about the XBox Series X which has a more powerful GPU?
Something going on with the forum, I keep getting double posts.
Y
That is why I can’t see those prices being accurate. I can see the 3070 being around £500 though, especially if it has 16gb vram.
Seems I will be skipping the launch as the 3070 comes in October. Fine by me as I need the card in November anyways. I would go 3080 if it was £600 but looks like they will want £800 for it, so they can keep that.
No-one will probably even notice with all the spam going on in this thread.Something going on with the forum, I keep getting double posts.
make mine a double if your buying mate lol
2600 comments holy ****NVIDIA GeForce RTX 30 ‘Ampere’ Graphics Cards Rumors: RTX 3090 24 GB, RTX 3080 20 GB, RTX 3070 16 GB , Double The Ray-Tracing & DLSS Performance Over Turing
https://wccftech.com/nvidia-geforce...rformance-ampere-gaming-lineup-rumor-details/
Honestly 16 GB 3070, equal in performance to a 2080ti, but for like $600? I'd be worried of ever finding it in stock.
It will and big LOL moment if the consoles as well will be closer to $1000 mark!
