Currently I have a gtx 295 and I'm thinking it's time for an upgrade.
I'm thinking of a gtx 660 (under £200 region anyway).
My main question is, will this card be compatible with my mobo. It's a "Gigabyte GA-EX58-UD5 Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard".
Existing gtx 295 has 2 power sockets plugged into it.
Also, does the card just take up 2 slots height wise in the case?
And is it any longer than the 295. Can't imagine it would be as then it wouldn't fit most cases??
Final question, how much of a jump in performance would I see?
). Looks like I would need to go for a 680 to get much of a "hit".
