Nvidia Forceware 270.51
Caporegime
8 Sep 2006
On Ocuk
Because people can't read the links and the information provided this is a
BETA DRIVER
BETA DRIVER
BETA DRIVER
BETA DRIVER!!!!!!!!!!!!!
YES, A BETA DRIVER!!!!!!!!!!!!!!
LINKS
WIN7/VISTA 32BIT
http://www.nvidia.com/object/win7-winvista-32bit-270.51-beta-driver.html
WIN7/VISTA 64BIT
http://www.nvidia.com/object/win7-winvista-64bit-270.51-beta-driver.html
This is the first release from the Release 270 family of drivers (versions 270.xx to 274.xx). You can read more about this family of drivers on GeForce.com.
This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, 400, and 500-series desktop GPUs as well as ION desktop GPUs. This driver package also includes the 3D Vision Controller driver.
New in Release 270.51
GPU Support
Performance
  • Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers. The following are examples of some of the most significant improvements measured on Windows 7. Results will vary depending on your GPU and system configuration:
GeForce GTX 580:
    • Up to 516% in Dragon Age 2 (SLI 2560x1600 8xAA/16xAF Very High, SSAO on)
    • Up to 326% in Dragon Age 2 (1920x1200 8xAA/16xAF Very High, SSAO on)
    • Up to 11% in Just Cause 2 (1920x1200 8xAA/16xAF, Concrete Jungle)
    • Up to 11% in Just Cause 2 (SLI 2560x1600 8xAA/16xAF, Concrete Jungle)
    • Up to 7% in Civilization V (1920x1200 4xAA/16xAF, Max settings)
    • Up to 6% in Far Cry 2 (SLI 2560x1600 8xAA/16xAF, Max settings)
    • Up to 5% in Civilization V (SLI 1920x1200 8xAA/16xAF, Max settings)
    • Up to 5% in Left 4 Dead 2 (1920x1200 noAA/AF, Outdoor)
    • Up to 5% in Left 4 Dead 2 (SLI 2560x1600 4xAA/16xAF, Outdoor)
    • Up to 4% in H.A.W.X. 2 (SLI 1920x1200 8xAA/16xAF, Max settings)
    • Up to 4% in Mafia 2 (SLI 2560x1600 AA on/16xAF, PhysX = High)
GeForce GTX 560 Ti:
    • Up to 461% in Dragon Age 2 (SLI 1920x1200 8xAA/16xAF, Very High)
    • Up to 241% in Dragon Age 2 (1920x1200 4xAA/16xAF, Very High)
    • Up to 19% in Just Cause 2 (SLI 2560x1600 8xAA/16xAF, Concrete Jungle)
    • Up to 13% in Just Cause 2 (1920x1200 4xAA/16xAF, Concrete Jungle)
    • Up to 5% in Call of Duty: Black Ops (1920x1200 noAA/AF, Jungle Map)
    • Up to 5% in H.A.W.X. 2 (SLI 1920x1200 4xAA/16xAF, Max settings)
    • Up to 4% in Call of Duty: Black Ops (SLI 2560x1600 4xAA/16xAF, Jungle Map)
    • Up to 4% in Civilization V (1920x1200 noAA/AF, Max settings)
    • Up to 4% in Left 4 Dead 2 (SLI 1920x1200 4xAA/16xAF, Outdoor)
    • Up to 4% in Metro 2033 (SLI 1920x1200 4xAA/16xAF, PhysX on)
NVIDIA Update
  • This is a new feature in Release 270 and later drivers. NVIDIA Update keeps your PC up-to-date with the latest NVIDIA drivers by notifying you when a new driver is available and directing you to the driver on www.nvidia.com. When you install a Release 270 or later GeForce driver from www.nvidia.com, you will be presented with the option to install NVIDIA Update. Click here to learn more about NVIDIA Update.
NVIDIA 3D Vision
  • With Release 270 drivers, the 3D Vision Controller driver is now included with all GPU driver installations. This driver package includes v270.47 3D Vision Controller driver. Users are no longer required to install a separate 3D Vision Controller driver or CD driver. For more information, please view this knowledgebase article for more information.
  • New features added to 3D Vision window mode
    • Adds support for HDMI 1.4 3D TVs when using 3DTV Play software, including DirectX 9 games, Google Earth, and 3DVisionLive.com.
    • 3D Vision window mode now works with Windows Aero enabled
    • New NVIDIA Control Panel option to toggle 3D Vision window mode on or off.
  • Performance improvements
    • DirectX 9 applications when using NVIDIA SLI
    • Better performance using the in-game crosshair for Half-life 2, Left4Dead, and Left4Dead2
  • Adds support for new 3D Vision Desktop LCD monitors: Tongfang LM2230W
  • Adds support for new 3D Vision projectors: Acer X1261P, Acer X1261-3D, DepthQ HDs3D-1, NEC NP-V300X, Sanyo PDG-DXL2000
  • Fixed problem with DLP HDTVs and SLI which caused problems with eye synchronization
  • Add support for new 3D Vision All In One PCs: Acer Aspire Z5673, Lenovo B520
  • Added the following 3D Vision game profiles:
    • Alice Madness Returns
    • Crysis 2 (including multi-player demo)
    • Dead Space 2
    • DeathSpank
    • Dragon Age II
    • Duke Nukem Forever
    • Dungeon Defenders
    • Dungeon Siege III
    • Fable III
    • Faxion Online
    • F.3.A.R.
    • Final Fantasy XIV
    • Homefront (DirectX 9 and DirectX 10)
    • Lego Universe
    • Need for Speed World
    • Portal 2
    • Richard Burns Rally
    • Rift
    • Section 8: Prejudice
    • Shift 2 Unleashed
    • Shogun 2: Total War
    • Star Wars: Clone Wars Adventures
    • Test Drive Unlimited 2
    • The Sims Medieval
  • Updated the following 3D Vision game profiles
    • MX vs. ATV Reflex
    • Monster Hunter Frontier Benchmark
NVIDIA Surround
  • Adds 3D Vision Surround support when using 3D Vision monitors with built-in IR emitters
  • Increase performance for GeForce 200 series, 400 Series and 500 Series GPUs in several DirectX 9 PC games vs. the latest Release 265 drivers. The following are examples of some of the most significant improvements measured on Windows 7 64-bit. Results will vary depending on your GPU and system configuration.
GeForce GTX 480 SLI in 3D Vision Surround:
  • Up to 109% in Aliens vs. Predator (5760x1080 1xAA / 16xAF)
  • Up to 107% in Burnout Paradise (5760x1080 2xAA / 16xAF)
  • Up to 267% in Call of Duty Black Ops (5760x1080 2xAA / 16xAF)
  • Up to 177% in Call of Duty: Modern Warfare 2 (5760x1080 2xAA / 16xAF)
  • Up to 15% in Far Cry 2 DirectX 9 (5760x1080 2xAA / 16xAF)
  • Up to 250% in Left4Dead2 (5760x1080 2xAA / 16xAF)
  • Up to 159% in Need for Speed Shift 2 (5760x1080 2xAA / 16xAF)
CUDA
  • Adds support for applications using CUDA 4.0 features such as Unified Virtual Addressing (UVA) and GPUDirect™ v2.0.
Other
  • Installs HD Audio driver version 1.2.22.1
  • Installs PhysX System Software to version 9.10.0514
  • Supports playing back Blu-ray 3D discs when connecting your GPU to an HDMI 1.4 3D TV. Playback requires compatible software application from CyberLink, ArcSoft, Roxio, or Corel. For GPU and system requirements, visit the NVIDIA Blu-ray 3D website.
  • Supports the new GPU-accelerated features in Adobe CS5.
  • Supports GPU-acceleration for smoother online HD videos with Adobe Flash 10.1. Learn more here.
  • Supports the new version of MotionDSP's video enhancement software, vReveal, which adds support for HD output. NVIDIA customers can download a free version of vReveal that supports up to SD output here.
  • Supports DirectCompute with Windows 7 and GeForce 8-series and later GPUs.
  • Supports OpenCL 1.0 (Open Computing Language) for all GeForce 8-series and later GPUs.
  • Supports OpenGL 3.3 for GeForce 8-series and later GPUs.
  • Supports OpenGL 4.1 on GeForce 400 series and later GPUs.
  • Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel X58-based motherboards.
  • Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software.
  • Users without US English operating systems can select their language and download the International driver here.
Always Tick the CLEAN INSTALL OPTION in Custom, for a cleaner install ;)
Would be a much better idea to add in Beta to the title, was just about to download them.
:( ill wait for the official release, But thanks very much for posting them looks some interesting stuff in there. Nice increase on DA2 also :D
You will be waiting a VERY long time, perhaps May
Just to make it perfectly clear, this is a beta driver :rolleyes:
The driver that came with the GTX 590 was an official driver, that worked out well didn't it? POP!
LOL @ DA2 performance increase. It's perfectly playable with everything maxed @1920x1200 on my SLI GTX470 SOCs already. A 300%+ increase in performance should make it super smooth.
Taken them long enough to sort out the terrible DA 2 performance. Hope this is better than the last DA 2 fix one :)
Tried them going from 267.59 driver and they do infact seem better as i can turn everything on now at 1920x1200 with 8xmsaa (before i was playing with 4xmsaa and depth of field/ssao/high quality blur turned off) and both times using high res textures.Still though outside areas can suffer somewhat fps wise but at least it's a lot more playable than 266.58 that's for sure at these settings.
