- 6 Dec 2013
- Nottingham
does anyone know if nvidia support freeesync over hdmi yet without/prior to hdmi 2.1 (i/e 1.4)? i presume not but the monitor im curious about is an LG 29WK500
I have a QLED TV too and freesync over HDMI will not work on the current (RTX2000) nvidia cards. I had to buy an AMD 5700XT to do 120hz freesync.Interesting. Currently im using a Samsung Q70R 55" tv it is 120hz and has Freesync. So I'm guessing it'll work ok with a 3080 via HDMI.
I have a ru8000 Samsung and from what I could find it seems the freesync on Samsung TVs is AMD only unfortunately.Interesting. Currently im using a Samsung Q70R 55" tv it is 120hz and has Freesync. So I'm guessing it'll work ok with a 3080 via HDMI.
That suck.I have a QLED TV too and freesync over HDMI will not work on the current (RTX2000) nvidia cards. I had to buy an AMD 5700XT to do 120hz freesync.
The 20 series don't support it according to rob77, but it does look likely 30 series will. So it's worth waiting a few weeks to find out before buying.2000 series does have vrr over HDMI, it's just Samsung TVs only support AMD freesync, not vrr.I don't understand the logic of this discussionThe 20 series don't support it according to rob77, but it does look likely 30 series will. So it's worth waiting a few weeks to find out before buying.
I'm STILL confused. Where on this thread is the currently unreleased/untested 3080 confirmed to not work with VRR TVs?
so you are saying nvidia will support a spec that doesn't exsist prior to hdmi 2.1? do you have any evidence of nvidia taking up support of vrr in the old hdmi standards? this will be a good outcome if the case.HDMI VRR is different than Freesync over HDMI. Some TVs support HDMI VRR others Freesync over HDMI and some both. Nvidia should without a doubt support HDMI VRR on TVs with support for it, while it's uncertain if they will also support Freesync over HDMI on TVs with support for it.
Nvidia is already supporting VRR with Turing on a 2.1 enabled TV with support for it. While you won't get the 48Gbit bandwidth you will get the VRR support as long as your drivers are up to date. It works with TVs like LG C9, E9, B6, and CX. Plenty of videos around showcasing VRR in action on LG's OLEDs with Turing.
https://www.overclock3d.net/news/gp...i_2_1_vrr_support_to_its_rtx_20_series_gpus/1
https://www.reddit.com/r/Amd/comments/dtj9qg/nvidia_now_supports_hdmi_21_vrr_as_of_their_last/
https://forums.overclockers.co.uk/t...ts-rtx-20-and-16-gpus-not-10-series.18867626/
