- 20 Aug 2012
- Greater London
Well i thought it might be about time that i upgraded my 4 year old nvidia geforce 8800GTX graphics card, but i wanted to know what the modern day equivalent was
I think what OP meant by "8800GTX equivalent" is not a card that's around the same speed of 8800GTX, but like the equivalent teir in terms of current gen cards.http://www.anandtech.com/bench/Product/612?vs=521
This will give you a good idea. The 8800gtx is little faster than the gt so that would put it right next to a 640 (game performance only). This is despite the fact the 8800gtx has much less stream processors. If you look at the gt440 it gets smashed by the 8800's.
£200-£450??!!! Thats a really wide range.
What resolution do you game at and what sort of games you looking to play?
1. State how much you prepared to spend
2. State the spec of your current PC (particularly the CPU and PSU)
People would then be able to give you some suggestion.
If you got around £450 budget, this is what I would suggest in terms of upgrading:i have core 2 quad (unfortunately, all my parts come from an old PC) overclocked to 3.4 GHz and a 700watt cooler master GX Lite.
i5 2500K (2nd hand): £120
Gigabyte Z77-D3H Intel Z77 motherboard: £80
2x4GB DDR3 1600MHz memory: £35
HD7950: £230
Total: around £465
HD7950: £230
Total: around £465
I thought the OP only wants to upgrade the GPU?
You must be thinking that core2quad is gonna bottleneck anything higher than a HD 7850?
