Nothing's changed since I did it on the 3080FE it seems.nice. here's a good guide to undervolt
Done a quick safe test of 0.925 2900MHz @ 100% power and was a couple points better in Speedway.
I'll tweak more after work.
When I change the config file and save it. Reopen Afterbuner and nothing has changed. Tried several times.nice. here's a good guide to undervolt
if you are happy with the config then you click the windows icon to make it blue so it applies that config when it starts. also in the settings there is an option to start afterburner when windows starts.When I change the config file and save it. Reopen Afterbuner and nothing has changed. Tried several times.
Did you try copying the file to your desktop, editing it and then copying it back over the original one?When I change the config file and save it. Reopen Afterbuner and nothing has changed. Tried several times.
The DLSS 4.5 over-ride doesn't appear to work for me if I'm using ray reconstruction (according to the nvidia overlay anyway) - is that how it is supposed to work?
If ray reconstruction on it shows SR Model OVR as inactive. If off it shows it as preset M.
(I've tried this out in cyberpunk and Alan Wake II)
Assuming you're comparing like for like, it can be down to the power drawn. The lower voltage set up will draw less power which may lessen any power limits you're hitting in the benchmarks.Another UV question (sorry). I have two UV profiles in MSI AB - 1) 0.9mv @ 2750Mhz & 2) 0.9mv @ 2800Mhz. The first one I created months ago and the second one the other day. However... the first one (2750Mhz) boosts higher in games and benchmarks. How is that possible? Is the MSI AB curve a rough guess at best? It's best strange. I thought i'd do some tinkering again as it had been a while and stumbled across this.
Yes, they were like for like comparisons. Everything is stock aside from the undervolt.Assuming you're comparing like for like, it can be down to the power drawn. The lower voltage set up will draw less power which may lessen any power limits you're hitting in the benchmarks.
To be honest, so few games I play, even at 4K 240Hz, draw the full 600W that I find benchmarks not mega useful. But no reason not to run the lower voltage set up if it's stable and giving better performance. I was running mine at 3200 MHz for ages before backing it off during summer where I thought I was going to melt. Even then, only a couple of actual games hit the power limit.
no, but what you can do is get hwinfo to log stats to a txt file. then upload the txt file to chatgpt to help determine what went wrong.Anyone ever had an issue where an undervolt will cause Windows 11 to do a grey screen system lock forcing a hard reboot ?
