Nvidia Shield / Kodi issue?
30 Sep 2004
Wiltshire
So i finally got a new TV, picked up an LG C6 OLED, bought an nvidia Shield and put Kodi on it. All works fine, or does it? Something just doesnt seem quite right and I can't put my finger on it.
When I watch movies it seems as though something funny is going on with the framerate, but it could just be that I'm not adjusted to my new TV. It's really hard to explain, but for example Secret Life of Pets on Sky Q in UHD looks really smooth and great, if I play it though Kodi from a file it doesn't look quite as smooth. Same issue with Kong Skull Island. is it my eyes? Is it actually better through Kodi and I'm used to not such a good TV? Does anyone even know what I mean or am I crazy?
EDIT : Should mention that I don't notice it when watching the same file through my monitor or the old TV using a PC with KODI.
Ive tried Kodi and the SPMC branch with these settings
adjust display refresh rate = on start / stop
pause during refresh change = 3.0 seconds
sync playback to display = off
Videos > Acceleration
enable HQ scalers = low
allow hardware acceleration - Mediacodec (Surface) = off
allow hardware acceleration - Mediacodec = on
accelerate MPEG2 = HD and up
accelerate MPEG4 = HD and up
accelerate h264 = HD and up
accelerate hevc = HD and up
System > Video Output
set GUI resolution limit = unlimited
vertical blank sync = always enabled
OSD Video Settings
While playing a video, go to the OSD > Video Settings
deinterlace video = auto
deinterlace method (SD/software) = yadif (2x)
deinterlace method (HD/hardware accelerated) = bob inverted
video scaling method = lanczos3 - optimised
and these on my tv
Picture Mode Settings: Expert(Dark Room)
Aspect Ratio: Original
Energy Saving: Off
Eye Comfort Mode: Off
OLED LIGHT: 38
Contrast: 100
Brightness: 50
H Sharpness: 0
V Sharpness: 0
Color: 50
Tint: 0
Dynamic Contrast: Off
Super Resolution: Off
Color Gamut: Normal
Edge Enhancer: Off
Color Filter: Off
Gamma: 2.2
Color Temperature: Warm2
Noise Reduction: Off
MPEG Noise Reduction: Off
Black Level: Low
Motion Eye Care: Off
TruMotion: Off
Ultra HD DEEP Color: On
Yeah that's the exact page I used thanks. I think I've kinda solved it by using TruMotion and setting Dejudder and Deblur to 0. Real Cinema is greyed out in TV options which is for 24p content and I cant enable it so thats not helpful
Does your tv say the frame rate has changed when you play a film?
Can't remember exactly where but I know there are a few frame rate options in different places.
I'd stick with SPMC as well, both plex and kodi give me hd audio drop outs.
Real Cinema will be greyed out if you have trumotion enabled.
If you disable trumotion, but you can't enable Real Cinema, then the tv is not playing at a refresh rate that supports it (24p) and is probably instead using 60fps and 3:2 pulldown or similar.
