Hi, I have just changed graphics card to a GeForce GTS250 and have a strange problem with screen resolution, anyone have any ideas how I can fix this ?
Windows 7 64bit
GeForce GTS 250 512Mb
Hanns-G HW191D 19" widescreen monitor
The monitor preferred resolution is 1440x900, this is what it has been running at for the last couple of years with an old Radion graphics card.
The Radion card died and I have replaced it with a GeForce GTS 250.
Now when connecting the monitor using a DVI cable windows does not give me the option of 1440x900, it also does not appear to detect it is connected to the Hanns-G monitor.
After lots of installing/un-installing of graphics card drivers and monitor driver file I connected using a VGA cable and windows automatically sets the resolution to 1440x900 and shows the Hanns-G monitor as the display.
Changing back to the DVI cable and the same problem occurs, switch back to VGA cable and all fine.
I think the picture is crisper with DVI so would like to get this fixed.
Any ideas/suggestions on how I can get the DVI connection working correctly ?
Thanks
Windows 7 64bit
Thanks
