Nvidias new way of using VRAM?
28 Aug 2014
When the 900 series of cards where released it was said by Nvidia that these cards will be able to handle the needs of more VRAM because of the way they use it... Or something along them lines.
Now it's been over 6 months since the release I have not seen one case where 4GB on a AMD card is less valuable than 4GB on a Nvidia card. What happened to this?
Will probably come to light that I have misunderstood something along the way lol.
Yer, I think you have misunderstood and it was the way the 256bit bus coped with memory compression. It wouldn't actually mean using less VRAM, just a better way of dealing with compression.
AMD do the same as well.
Edit:
This article explains it far better than I could
http://www.anandtech.com/show/8526/nvidia-geforce-gtx-980-review/3
Scroll down to Colour Compression.
Have you not heard about the GTX 970 !!!
I think I will get my coat.:D
Edit:
a few words in your post made alarm bells go off in my head and then i thought oh yeah that is what it said.
+1
The whole GTX 970 business was totally over the top.
The proof is the cards are still selling in their thousands.
The proof is the cards still perform well - lots of people buying something don't make it technically good, just good from a business standpoint :p
(I agree it was overblown!)
+1
Proof the average consumer is a mug :P
That said for <4K gaming 3GB is generally adequate though I get quite close to maxing it out sometimes.
Who said its specifically a 4k card? The 900 series were marketed just as much as 4k cards as the fury currently and will be.
In fact 900 series were considered better 4k cards than 290x cards so why are they now only 1080p? Coz of tx and ti? Funny how goal posts move when it's suited to certain ppl.
Lossless colour compression is a technology that improves bandwidth efficiency arguably refuting the need for more memory bandwidth. How well it worked in the case of the 980GTX (and 970GTX) is questionable. It doesn't reduce the amount of memory used.
This content filtering is handled by the middleware and the developers for a large part.
Also the 980GTX was never marketed as a 4K card, if that's what some are saying here
Will you stop trying to correct me... Just look at the description on the cards here at ocuk
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Just one example. Sure if u look on nvidia website it will tell u more. Also remember nvidia peeps saying 980 cards were better for 4k than 290x 8gb cards lol. Ark at that.
And before you pick up on the support bit fury will only say the same supports 4k so like I said marketed only the same.
