Nview help?
22 May 2006
I had always nvidia cards, but there are new features I don't get how to use.
On the Nvidia website, the help info is not much, just an overview.
First from the new control panel how to go to nview?
On "Desktop Management", On "Applications" what does the check box "Globally disable all individual settings and window memory"
On "Desktop Management", on "User Interface" check box Enable "Grid lines".how you use it, I know is to set places for your apps, but there is no tutorial or help in nvidia.
Thanks
