Hi All,
I currently use the cooler master elite 330 but lately maybe due to the summer my temps have been of concern. My phenom 2 idle @ 45 and 40 for the case temp.
I want to reduce the internal temp in the case as well as the CPU.
I currently have 2 120mm fans pushing air out of the case.
a) Am thinking of getting a cosair h50 against the artic freezer pro am using if i dont need to change the case or
b) I am thinking of getting above case and get extra fans to push the hot air out of the case but am concerned the noise as i wouldnt want a noise case. Can anyone advice on this.
Thanks in advance.
Thanks in advance.
) and if that doesn't sort things out, you would then have a little left over for a better cooler
