Nzxt H2
I just did a review on this case today: http://www.vortez.net/articles_pages/nzxt_h2_review,1.html tbh I don't know what OC3D have got a problem with, to be so overly critical like that and you will notice in the video he comes across very arrogant and with no constructive criticism. It appears like other videos/reviews he has done that he is creating this negative review to try and get more exposure and traffic to the site.... Another 3 sites have already praised the case:
http://www.legitreviews.com/article/1574/1/
http://metku.net/index.html?path=reviews/nzxt-h2-classic/index_eng
http://www.sweclockers.com/recension/13680-nzxt-h2 (not english)
From my own experience its a good case tbh :)
Good review - I quite like the styling personally, it's just got a little more flair than the Fractal, which to me is simply a box, while this has some nice detail. On the other hand, I suspect the feel will be slightly cheaper than that of the Fractal, but that's only a guess.
I really like the review. Quality feel is the most important thing on a case to me, glad to see someone covering it properly!
Tom is a very good reviewer, it is nice to see them being so frank and reviewing it properly, not many reviewers would have the guts to do that! For example, if 3DGameMan got one, he would just look over the case, pointing out the good bits, moan about the lack of a removable motherboard tray and then call it a Kickass product!
Fair's fair, it looks like a great case from the outside. I would like to see them do it again with a metal construction and putting more care into the quality, design is good but the execution seems poor.
haha beat me to it :p I was going to post that, drop in the youtube tags mate ;)
It does have some good features, it didnt deserve the beating it got at OC3D imo.
Much better video! Not because I'm biased but because it was actually thorough and you bothered to put something inside to show what it's like.
OC3D Tom may have been overly critical in many respects, but you can't deny that case flexes like a bitch when he applied a little pressure, that foam padding does look cheap, the front-loaded hard drives are a waste of time if you have to open the side panel to disconnect cables anyway and what IS up with that magnetic panel up top?
Yes, it's a R3 ripoff, no that's not necessarily a bad thing, but it's too expensive for what it is.
I'm personally siding with Tom's overall opinion
I really don't understand the point of sound-proofing to reduce fan noise when the sound proofing completely blocks the air flow.
