NZXT Phantom 410 - First Build
Installed the OS to the SSD. Just re-formated and deleted data from the SSD, reinstalled okay, just performing windows updates again and see how it goes. Any other ideas what could be causing the issue that could be hardware related?
First install was with HD unplugged. So just picking up the SSD. This install was with the HD plugged in. If issue continues should I try putting the OS on the HD instead? I heard could be firmware issue with the SSD no options for an update on corsair website and checked update through device manager and says best update already installed
well in the first instance , put your cpu back to defaults and see if the problem is still there, there will be an option in your bios somewhere for that, but im a gigabyte person, so I dont know my way round an asrock bios
