NZXT Phantom - White
I just want to echo what Shayper said; I wasn't having a go at you rjkoneill, just simply putting my opinion across. I appreciate your opinion especially as you work for OcUK and as you say, you should be trying to sell us this stuff :p
Unfortunately it looks like I have to send the whole case back to OcUK to get it replaced for a new one, all because of a couple of missing cables :( I don't know how I'm going to survive for that long without a PC *twitch*
question: on the side of the box it says 1xBlue LED 200mm fan included, yes i see the fan included however i see no leds?
There's a button on the top of the back of the case that turns the LED's on and off.
Hope that helps :)
Hope that helps :)
I spent all day yesterday with no 200 mm fan in Blue, I wished I new about this button, I have had problems trying to find another Blue 200mm fan to sit along side the pre-installed one.
I have this case in Black, lovely bit of kit, but I think NZXT could have made more stock fans available, or put an extra option to buy the case fully loaded with pretty fans!
The case is a lot bigger in real life and I am struggling to find a nice glass desk to show it off!
the stock photos made it look amazing
unfortunatly it is just the standard NZXT fayre.
cheap plastics
poor hard drive cages
thin cheap metal panels
average paint job
flimsy, unnecessary door
shambolic watercooling support
overpriced
Sad to hear this :( Was thinking about building a new rig in one, looks really, is quite roomy and has great cable management. Did think it was way to steeply priced anyway though, wouldn't want to pay more than £100 for it.
that is one persons opinion i really like mine and disagree with most of thise comments, if i didnt like it, i would have sent it back.
Sum this up, Case is amazing!! And its tough not flimsy plastic... I got so excited when I rebuilt my pc within the NZXT case (White) i actually dropped the case, and can report no damage at all not even a scuff. I'm so pleased with it!! fits the i7 build nicely and the fans are so quite on full power! so much room and cable management, best case ive had!
i got the Corsair H50 anyone know if this fits in the case
No it doesnt and nzxt is aware of this and have stated it on there site. The rad hits the top 200m fan, i suppse you could mount it at the front if you wanted but its not ideal.
ok thanks ,counts out this case for me then
just looked on there website but cant find anything have you a link please.
Has anyone tried it out with the additional side fans? I'm wondering what that does for airflow, because I'm pretty sure that massive 200/230 should probably mess up airflow... and if it does, fantastic, because I had a mod plan that meant I didn't want it in there anyway! xD
kd
I'm awaiting delivery of this case for my new build, in regards to the H50 i think it's pot luck as some people it's fitted without obstructing the top fan others it's caught,from what I've read on the nzxt forums there moving the holes down slightly on the new batch, also I think you only have 154mm height with a cpu cooler unless you remove the side fan
its a great case, but it has some really bad flaws.
H series coolers wont fit (some people got lucky and it will)
but if your not in a rush there allready re making this case with improvments.
I have this case and have the H50 on push pull fan system fits easily.
(funny enough its not a case I would normally buy, well not in white, got it on the cheap ..must say it has really impressed me, such a easy case to work in :))
