- 17 Dec 2018
Hello,
My pertinent system specs are:
NZXT S340 Elite
Asus Maximus Code IX
Intel i7-7700K
G-Skill Trident Z RGB (2x8GB)
Asus ROG something or other 1070
Had a NZXT Kraken X62 v1 for cooling, up until yesterday when the pump decided to give up. Was the first AIO I had bought..and probably the last. Hence looking for a suitable Air cooler recommendation which has adequate clearance for my components and fits within the case.
Was going to go for the Noctua DH15 or something similiar, but believe its space may be tight?
My brother's got an Cryorig H7 for his i5-8600 in the same case, seems to perform well, so that may be an option?
In addition to the air cooler, I'll probably need to get an intake fan, as I had my kraken 280 radiator at the front - whats the recommendation -> 1x 140mm Noctua fan or worth getting 2 for front intake?
Currently have the stock NZXT fans that came with the case in their default exhaust locations (rear and top).
Thanks
NZXT S340 Elite
Intel i7-7700K
Thanks
