my friend has just built his own p.c (pretty cheap one), and he found the o.s would not install under the IDE option in the BIOS, so he installed in under the other option RAID, and it works perfect, the problem comes now when he adds another HDD, the machine will boot and say HDD failure insert system disk, which he hasnt got. and if he switches the BIOS to IDE the system will load XP then shutdown due to a technical error that comes up with the blue screen.
any ideas on how he can either get it back to IDE (which is starnge becuase he uses sata HDD's)
and get his other hdd's installed and working :S
lol if you want any more specifics just ask
