- 3 Feb 2009
I would say P12 but it sounds like you're after the RGB. I hear the new Lian Li SL120's aren't bad if you're that way inclined.
3 times the cost
Static pressure
P12 2 .2mm
Thermaltake 2. 41mm-
EK Vardar EVO? I have 3 in my current system on my rad and I never ever hear them. Can get them in pretty much any colour (black, white or RGB if you are that way inclined), decent static pressure (3.16mm on the 120mm variant) and also shifts a decent amount of air.
Downside? As with most EK things, the price.
Yes if you use the Distro plate it takes up one of the spaces for the radiators leaving you with only two options for 360mm radiators.I'm looking to move in to the XL case after 4 years in a Parvum, we built my lads rig in the non XL and had to mod it to get the 360 in the roof and side, bit of effort but good end result, I want to do 3 x 360 does this rule out the front Distro plate? I'm being lazy I know and I think it probably does? I want a 360 for the 6950x CPU and 2 x 360for the 3090 FE (in case it gets a mete later)
so which district plate is that? is it for the std or xl o11?
re the bottom add on to the o11, one advantage, I think, would be keeping the heat away from the main case
