I have a 54mm on top and bottom with the same front distro plate
Any pics, I have zero room for any more rad so intrigued to see how you fitted a 54mm at the top! Unless you removed the top case panel and put the fans on the outside...?
on night shift so will post some up on Wednesday The fans are mounted to the rads inside the case It will also house a 3090 rtx vertically once evga sorts my que out
@SS-89 Sorry totally forgot about posting Bottom pipes are now just like the top ones as I have modded vertical mount to fit will post more pics of how it is now still waiting for my 3090 currently rocking a 2080ti
Awesome looking builds! Out of interest - where on earth have you hidden the PSU - can't see it in the pics?
