- 5 Jan 2010
I'm being switched over to O2 broadband tomorrow so I'd better start to prepare.
From the O2 "Use your own router" article I found this:
My router is a Linksys WAG320N(http://www.linksysbycisco.com/UK/en/products/WAG320N)
Just wondering what I put for Encapsulation and QoS, and does anyone know where I can find Line Attenuation?
edit: as I'm planning to use my router instead of the o2 one, should I clone the O2 routers mac address?
Code:
* ISP name: O2 Home Broadband
* Multiplexing method: LLC-Based
* VPI: 0
* VCI: 101
* Username: leave blank
* Password: leave blank
* Domain name: leave blank
* IP address type: this depends on whether you chose our static IP address option or not:
- If you didn't choose our static IP address option, set this to dynamic IP
- If you did choose our static IP address, enter the IP address printed in your welcome letter
* DNS servers: choose to get these dynamically from the Internet provider
* NAT: enable
