O2 LLU speed drop
28 Aug 2005
Been on O2 LLU for about a year and have had no complaints.
The past few weeks however my speed seems to have dropped from 5 mb/s to 3mb/s resulting Web browsing and iplayer etc taking longer to load. The strange thing is the sync speed is still the same and torrents and downloads run at the same speed they always have.
Anybody got any ideas?
Current line stats below:
Uptime: 0 days, 0:33:18
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,165 / 4,975
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 0.00
Output Power (Up/Down) [dBm]: 12.0 / 19.0
Line Attenuation (Up/Down) [dB]: 29.0 / 51.5
SN Margin (Up/Down) [dB]: 6.0 / 6.0
Vendor ID (Local/Remote): TMMB / BDCM
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 0 / 0
FEC Errors (Up/Down): 31 / 1,486
CRC Errors (Up/Down): 31 / 2
HEC Errors (Up/Down): 107,507 / 2
DSL Status: UP
DSL Modulation Mode: Auto
DSL Path Mode: INTERLEAVED
Downstream Rate: 6920 Kbps
Upstream Rate: 1215 Kbps
Downstream Margin: 6 db
Upstream Margin: 6 db
Downstream Line Attenuation: 41
Upstream Line Attenuation: 40
Downstream Transmit Power: 22
Upstream Transmit Power: 12
LOS Errors: 0
PVC Connection
PVC Status: UP
Encapsulation: RFC 1483 Bridged
Multiplexing: LLC
Autodetect: Disable
VPI: 0
VCI: 101
Current after reboot.
DSL Status: UP
Downstream Rate: 8038 Kbps
Upstream Rate: 1011 Kbps
Upstream Margin: 9 db
Downstream Line Attenuation: 39
Upstream Line Attenuation: 39
Downstream Transmit Power: 21
LOS Errors: 0
PVC Connection
PVC Status: UP
Multiplexing: LLC
Autodetect: Disable
VPI: 0
VCI: 101
Do sync rates drop over time as a norm. I have not rebooted my modem for a couple of months.
Im back to my normal speed. After the reboot.
DSL Status: UP
LOS Errors: 0
PVC Connection
PVC Status: UP
Multiplexing: LLC
Autodetect: Disable
VPI: 0
VCI: 101
DSL Status: UP
LOS Errors: 0
PVC Connection
PVC Status: UP
Multiplexing: LLC
Autodetect: Disable
VPI: 0
VCI: 101
Most modern ADSL modems automatically adjust themselves to keep the line stable. You have a lot of HEC errors, so your line probably isn't that great.
Over a few months, seeing a few Mbit drop doesn't suprise me at all.
You don't give any error numbers though, other than LOS (Loss Of Signal). As suggested, your sync rate will drop over time to a point where the connection never drops.
