bigbilly50 said:Just started this myself and got that fishy quest - do you need to go fishing (with a rod) ? The quest marker is in the middle of the lake....
KennyBhoy said:I've clocked up 40 odd hours on this now on the PS3. Last night i got bitten and i'm slowly becoming a Vampire. I was going to cure it but reading up on it, it sounds like it could be quite handy![]()
Baz said:I thought that as well, its a PITA!!!
You can't go out during the day, unless you suck some blood every night, which becomes tiresome, though the night vision and detect life are very handy in dark mines![]()
R0551 said:I accidently managed to heal myself so I can't become a vampire again
Tempted to redo it again and do things a little differently.
durbs said:The dark brotherhood is a good one to join early on as you get some slick armour straight off. Simply kill an innocent person but choose who you kill wisely: http://www.gamefaqs.com/console/xbox360/file/924363/42064
Also join the mages guild early on by visiting the guild in any town.
KennyBhoy said:See the daytime thing was a fear of mine as i CBA drawing blood all the time, i've only just became a Vampire (haven't slept since) and apparently once you sleep 4 times you become a full blown case?
Can you be cured at any stage or just early stages?![]()
msmalls74 said:Just goto to a chapel and use the alter thing if you havent slept should cure it, may work if you have and its less than 3 days since you got infected.
It's only really stage 3 and 4 where that's the case. As long as you feed regularly it wont be a problem.KennyBhoy said:Yeah i was just reading the Vampire FAQ on IGN and it doesn't seem as much fun as i first thought....Once your fully fledged, no one even talks to you![]()
wedgie22 said:It's only really stage 3 and 4 where that's the case. As long as you feed regularly it wont be a problem.
There's a decent guide to vampirism and the whole game here:
http://guides.gamepressure.com/theelderscrolls4oblivion/guide.asp?ID=964
for some reason I like guides with screenshots rather than the full text gamefaqs versions.
