Oblivion Help
10 Jul 2003
Birkenhead
Well just picked up a copy of Oblivion Been playing it Good so Far
But how on earth do to kill the Ghosts there casting a Spell on me
and i cant move?
Could Do with some Help and come tips Thx
Are they weakening you? Does it say "Your strength is being drained"? If so, you need to drop some stuff temporarily.
You can only kill ghosts with a certain type of weapon. Steel, iron etc won't work. You need enchanted weapons, but I think silver works too.
I'm sure you can kill them with your destruction magic (basic fire spell). Just stay back from them. You should be able to sidestep their projectiles.
Sorry to semi hijack, I've completed the game, but I never worked out how to drop items? How do you do it? :P
Regarding ghosts, I had that problem until I picked up a silver sword :) Also, some magic spells work against them, fireball seems to work against them quite well.
Shift + Click items, AFAIK.
To drop items make sure you are looking straight ahead with nothing immediately in front of you like a wall and then just click and hold on the item you want to drop. It pops into your and and you can swing it around and let go with your mouse to drop. Handy for throwing peoples shoes on roofs!
To kill ghosts use magic or a silver weapon. Daedric and enchanted weapons also work does not matter what the enchantment is.
Shift click is easier. :p
Regarding enchantments, if you have anything with Shock enchantment, this seems to deal out the most damage to ghosts - even if its just a crappy old iron/steel dagger, might be worth keeping hold of it for Ghost only use - or a touch shock spell, if you have or can buy one.
