Anyone know when the oblivion patch for the 360 version is likely to appear as im currently stuck due to a cutscene bug.. so i cant actually play the game anymore, until its fixed. Anyone know?
The PC patch is still a beta I think. When it's final they'll probably do a version for the 360.MadFruit said:There is a patch on the PC - who knows if they'll even bother for the 360.
I'm glad I got the PC version because a lot of these things can be fixed with console commands or fixes made with the construction set. There's one guy I had to respawn twice because he has a tendency to act like a lemming when you're not watching.[SKR]Phoenix said:I'm stuck on that Fighters Guild quest whereby the body you are supposed to find isn't there because apparently I visited the cave before the quest began.
Luckily I can still play the game, but can't finish the Fighters Guild quests. No biggie when you are on the PC, but that's a damn acheivement I can't get. Makes me sad...
pinkaardvark said:Can't you just load an old save?
Been stuck on that bug for ages now :/ The Fighters Guild was the first guild I did, until that bug stopped me in m tracks. Ended up doing all the other guilds and now await the patch to get my remaining quests done.[SKR]Phoenix said:I'm stuck on that Fighters Guild quest whereby the body you are supposed to find isn't there because apparently I visited the cave before the quest began.
Kainz said:Been stuck on that bug for ages now :/ The Fighters Guild was the first guild I did, until that bug stopped me in m tracks. Ended up doing all the other guilds and now await the patch to get my remaining quests done.
Alpha, have you tried clearing the game's cache? Start up Oblivion with the A button held down.
The Dark Brotherhood has some great little quests in it - better IMO than the Theives Guild ones (but then I'm not much of a fan of stealth!!). Some quite poignant killing sprees to be done![SKR]Phoenix said:What do you recommend doing first? Theives guild or the Dark Brotherhood? I've done the other two. Leaving the main quest for a bit.
I did that and then screwed up massively. Created a char, sniggered at P.Stewart dying, joined the FG and got upto their 4th guild mission, and then died after falling off a mountain! Only then did I realise that my last savegame was when I exited the sewers!Ultra_Extreme said:Tell me about it. Although as a TES veteran i think ill just start afresh with a Nord combat type that is heavily skewed toward health and swordplay, whak dificulty slider to 'childlike qand pathetic' and get the points
I had autosave, but some specific sub-options for it were turned off because I found it saving way too often. I had other reasons too, which I can't remember.McDaniel said:didnt you have an autosave?
