Or you can play the PC version chilled out on your sofa for hours.Lanz said:Its a big game, where you can spend hours and hours infront of your PC. I can see the attraction in the 360 version, as you can chill out on the sofa and play it, instead of hunched up on your pc for hours.
The thing about this is that, while it's not common, you can very easily set up a PC as a lounge machine. You can even go all the way and build a pure HTPC. Wireless gamepads and the comfort of the sofa can be had with both solutions, not forgetting wireless keyboards and mouse for anyone who uses those lounge trays for eating on.Caustic said:However, the main question is what you prefer and what your 360 setup is like. I like playing the game on my 42" screen whilst relaxing on the sofa with a wireless pad.
From what I have seen the Xbox 360 does not render any anisotropic filtering in Oblivion, and from what I have heard, it is only able to render 2xFSAA. Mods also increase the visual quality of Oblivion lightyears beyond anything the Xbox 360 will ever accomplish (see my screenshot a few posts up for aan example of very minor tweaking.)Caustic said:The game looks top notch on the 360 and the controls work very well. Performance wise, your PC would be close to the 360 or slightly better, but not a huge amount in it.
Lies.geeza said:graphics isnt everything though.
Úlfhednar said:Lies.![]()
