Oblivion v1.1.511 Patch
BTW - I did a search, Hope no one has already posted ;)
Change Log...
Bug Fixes
Fixed an issue with falling through collision in Fort Wooden Hand.
Fixed issue with remapping controls in French, German, Italian and Spanish versions.
Fixed issue with some shadows not lining up.
Going to jail while equipped with bound armor or weapons no longer crashes the game.
Fixed issue with bound weapons not dispelling properly after dismounting a horse.
Fixed issue with player shadow being delayed after fast travel.
Fixed infinite gold issue on some dead NPCs.
Fixed issue with disease resistences that made it impossible to contract vampirism under certain circumstances.
Fixed an issue where occasionally skills would not increase properly after you received an increase in a way other than skill uses like as a quest reward.
Fixed issue where spells, powers and lesser powers were being improperly resisted when the player cast them on themselves.
Fixed an issue where creatures and NPCs would not go into combat properly after being hit by a projectile.
Fixed an issue with duplicating items and unequiping the bow.
Fixed an exploit that allowed you to sell equipped items to a vendor more than once while on a horse.
Fixed an issue with items reappearing in dead bodies after saving and reloading.
Fixed crash when NPC with active light spell on them unloaded from memory.
New Very Low Quality graphic setting available under Launcher options with improved support for low end FX cards (5700 and lower). To use this setting, go to the Launcher, select Options and click Reset to Defaults to allow the auto detect to check your system.
Implemented SLI-mode optimizations on Nvidia cards, and Crossfire optimizations for ATI cards.
Fixed a crash issue where loading a save would crash if the player had extra data on them.
Fixed an issue for LOD art for city was not unloading quickly enough when exiting an interior.
Fixed an issue where Aylied doors would not open when activated in Miscarcand.
Quest Fixes
If you are permanently expelled from Mages Guild, you can now go back into the Mages Guild buildings.
In The Siren's Deception, the door to Gweden farmhouse is prevented from locking too soon if player exits too quickly.
In the Light the Dragonfires quest, player controls are prevented from being locked if player accidentally hits Ocato during the final battle in the Imperial Palace.
In the Confront the King quest, fixed an issue where Mannimarco would occasionally stop fighting the player while the player's controls are locked.
In Corruption and Conscience, fixed an issue if player got to Llevana's house earlier than expected and she would initiate trespass behavior rather than move the quest forward.
In Theranis' Mistake, it is no longer possible to get multiple copies of Ahdarji's ring. Also, fixed an issue with player receiving Blood Price topic too early in the quest.
In the Leyawiin Recommendation quest, it is no longer possible to bypass Kalthar in Fort Blueblood.
In Revenge Served Cold, Corrick will now recognize when player had the jade amulet in their inventory if No Stone Unturned quest had been previously completed.
In Infiltration, player can no longer kill Blackwood Company members and stop progress in Fighter's Guild.
In Dark Brotherhood, if you kill fellow members and get kicked out of the guild, you can no longer continue to progress in the questline until you redeem yourself and get back in.
In The Master's Son, the player now properly receives their reward when completing the quest.
In Caught in the Hunt, fixed an issue where NPCs would not go into combat properly.
In the Cheydinhal Recommendation quest, fixed an issue where Vidkun's body would disappear if you left the well.
Getting disqualified from the first Arena match no longer blocks you from further matches.
In Till Death Do They Part, the Count no longer rewards player with gold more than once. Fixed an issue with not receiving the Vampire Ashes topic if the player picked up vampire ashes before getting the quest. Fixed issue where Bloodgrass topic was not added if player finished the Main Quest before starting quest. Hal-Liurz will now follow player properly when asked about the cure.
In Mystery and Harlun's Watch, the dead body you are supposed to find will no longer disappear from Swampy Cave if you cleared out the dungeon before starting the quest.
In Blood of the Daedra, Martin will now recognize Spellbreaker as a Daedric artifact.
In When the Vow Breaks, additional instance of Rockshatter are now prevented from appearing on Bjalfi's dead corpse after saving and reloading.
In Paranoia, game no longer crashes when Bernadette Peneles exits the city while you are following her.
For Clavicus Vile quest, fixed crash with giving or refusing to give Umbra to Clavicus Vile.
Plugin Fixes
Fixed issue with saving your game while an actor is in a new interior cell created in a plugin, and re-loading the save game without the plugin.
Fixed issue with loading previous saves with plugin that contains new base objects that are containers, NPCs and creatures.
Fixed issue with linked pathpoints scripted to switch on/off that are modified by a plugin.
NPC's companions no longer disappear when they fast travel with player to an exterior cell that is modified by a plugin.
New scripted spell effects created in a plugin now work properly.
Ult1mateSlayer said:
This is a very old patch lol.
Actually it isn't in official form. It's been out in Beta for a while, but only just released officially by Bethseda today...
hmm, im having some problems installing this patch. Everytime i try to i end getting this msg:
Old file not foud. However, a file of the same name was found. No update done since file contents do not mach.
Any ideas?
is there a patch previous to this that i need to install?
oh this is a for a fresh install of Oblivion as well.
Thanks guys :cool:
i get the exact same error, seems they didnt beta the patch enough :eek:
me oblivion is a fresh install aswell =/
I had that problem when installing the beta with the OblivionLauncher.exe file. I don't think it causes any problems.
I have the same issue with most of the files with installing this over the beta patch. A fresh install should work. I hope my saves will work still :confused:
Any ideas?
Thanks guys :cool:
Did you download the US version rather than the Europe (English) one?
M
Im getting the same problem.
I was thinking maybe it could be something to do with a Mod installed? I got the mod where the fonts are smaller :confused:
I was having the error until I re-installed (which was a bugger to do) and then updated using the correct patch. All is fine now. :)
You're a bit of a gobby ****er lol.
That was uncalled for.
Curio said:
You're a bit of a noob lol.
To be honest, I was thiking the same thing as most of ES:OB community allready know the BETA version as been out for a while, but BETA was NOT mentioned in the OPs post, THUS meaning to myself it was the OFFICIAL release, THUS making your comment rather
"nOObish"
If your going to make such claims about someones post, make sure your correct in the future.
I'm dissapointed. At the moment my game feels unplayable.. I'm simply too weak. Any enemys I use to be able to kill I can't. Added to that I've become a vampire and the hassle that it intails I might as well give up on the game.
I was really hoping the patch would tweak the difficulty a bit.
(Writing this post has made me think that I could lower the difficulty but It would feel like cheating lol)
A simple responce like that would suffice, not some smartass remark.
What was your original response to the OP if not a smartass remark in itself? Hence my dig at your less than useful post. Pot, Kettle, Black, etc
How was it not correct :confused:
Anyway, for goodness sake, it was just a small dig at a silly and unhelpful reply. I suppose I should have stuck a smiley at the end. Silly me...
