OC causing problems?
22 Oct 2005
Moving...
I quite often get the message "oblivion.exe has encountered a problem and has closed, please report this problem...." when playing oblivion, like once or twice every few hours. Is this caused by instability of my cpu/ram/gfx or is it down to the game/windows? I would have thought its the game/windows cos instability would cause glitches/crashes or am i mistaken? Thanks
Hi,
You should make sure your CPU's overclock is stable with Orthos first.
Then if you've got mods for Oblivion disable them and try playing for a few hours. Or if Oblivion hasn't been patched recently you'll want to patch it with the latest updates.
If you've overclocked your graphics card it's unlikely that that will cause only Oblivion.exe to crash.
Banjo ;_;
