- 22 May 2009
- Guernsey, Channel Islands
OCing my 920 D0 2.66 atm and increasing the baseclock to 170 with turbo mode on to get 3.57 Ghz, i have the cpu voltage at 1.3, running at 1.288V and QPI at 1.3 also.
Running Prime 95 atm and hitting 65-68oC, i have read that i should run it for 30mins, then if ok, bump the baseclock up by 5 till it fails, what happens when it fails? i have had the temps go up to 85oC and nothing failed so i pressed stop, is this right to do or should i have left it?
many thanks
many thanks
