Hey all.
Was wondering if anyone could give me any pointers please, I only know the basics of overclocking etc, I brought a pre made bundle which was an i5 2500K stock 3.3Ghz overclocked to 4.5Ghz.
The system came with a H60 watercooler.
I have had it nearly 3 years now, and recently (usually playing microsoft flight simulator X) I am getting frequent BSODs.
Now, i have ran a few tests;
Firstly, I used FurMark to check my GPU, and it passed with no issues at all.
I then ran Prime95, On the ''blend'' test, and it crashed causing the BSOD in about 2 mins.
I took one of the RAM out to check, it did it again, then replaced with the other and it did it yet again.
I then put the stock profile on, and no issues arisen.
I have noticed recently that when i switch the PC on, it sometimes goes straight off again and usually restarts automatically (that may be of no relevance not sure).
So basically, I am stuck and really need some help if anyone has any ideas?
(My idle Vcore is around 1.176v)
Specs:
-Coolermaster 692 Advanced White gaming tower
-Intel Core i5 2500K 3.3Ghz stock Overclocked to 4.5Ghz (brought as pre made bundle at ************, tested etc.)
-Corsair H60 Watercooler
-GByte GA-P67A-D3-B3 MoBo
-8GB, 2x 4GB RAM
-1TB Samsung SATA HDD
-650w NZXT Hale Gold Modular PSU
-1024MB Gainward GTX 560 Ti Phantom.
Cheers, Adam
Specs:
-8GB, 2x 4GB RAM
Cheers, Adam
