DFI Infinity 975X (0707Bios)
X6800 stepping 6 b2
2Gb Corsair XMS2 8500 DDR2 Ram
and if it matters, Gainward 7900GTX with latest beta drivers.
I'm cooling on air, using a vapochill micro extreme, getting temps of about 56c load @3.31.
Which I would like to mention, is a son of a ***** to install that cooler, I think I MAY have put too much thermal paste (as5) on it, or not enough, not sure, read you put about a grain of rice or so on it and move it around a bit, but I never did that.
I've tried a multitude of settings, from what i've read around about.
Basically...
Multiplier is at x11 as you can't go higher on this board for some reason, I can't go to 320FSB or above.
Tried increasing voltages with no luck, on both the ram and cpu.
Also changed the FSB:RAM ratio, 400/533/800 doesn't change anything.
I'm not sure what I am doing wrong, what other information would you guys need to help me with my problem?
Post Screen, this is as far as I get on 320 FSB and 'freezes' here.
CPU
RAM, 800 in this pic, tried 400 also
X6800 stepping 6 b2
Basically...
CPU
