- 20 May 2012
hey ppl. new guy jason here, ill get to the point tho,
trying to overclock my system, cant seem to get the ram to overclock to well,
system specs are:
i7 920 d0 stepping / asus p6t se / 2x2gb g.skill ram 12800 1600,hz / nvidia gxt 260oc / wd hhd
my current (unstable oc) is at 3.6ghz, with ram at 1804mhz, if i underclock my ram it is stable, my bios setup is as follows.
oc xmp
1600mhz 9.9.9.24.2n 1.5v
cpu ratio 20
speedstep dis
bclk 180
pcie 100
dram 1804
cpu 1.225v
cpu ppl 1.9v
dram bus 1.64v
and disabled
cpu spreadspec
c1e
virt
cpu tm
speedstep
cstate
also ive been told to BCLK to 200 w/ the multiplier set to x18 = 3.6GHz w/ the x8 DRAM mult. = DDR3-1600. but then my ram is stock,
if anyone could work out were my problem is, would be greatfull cheers jason
system specs are:
oc xmp
cpu ratio 20
speedstep dis
bclk 180
pcie 100
dram 1804
cpu 1.225v
cpu ppl 1.9v
dram bus 1.64v
and disabled
cpu spreadspec
c1e
virt
cpu tm
speedstep
cstate
