- 16 Sep 2007
Hi all, this is my first post, so bare with me!
Ive a E6600, running on an abit AB9 mobo, with an artic freezer pro 7 cooler. also have a gainward 8800 GTS 320 GPU, X-cruiser case, with extra fans (ive added 2 extra front fans below DVD RAM drive (4x 80mm intake fans, 1x 120mm rear exhaust, 1x 80mm exhaust blow hole up top plus one small 40mm below the gpu, at rear of case).
Ive overclocked it to 3.2ghz and just concerned it may be running to hot. ive checked the heatsink is correctly fitted etc.
It idles around 33c and when under load from orthos, it'll run at around 47-53c.
Is this hot?? have i got it overvolted??
Im a bit new at this, so keep it simple. lol
i use it mainly for gaming, but also enjoy seeing how far it'll go, but before i do, i wanna check im ok so far.
Thanks guys
Thanks guys
