ocuk 3700 san diego why 20 quid difference
5 May 2004
hi all
looking for a cheap upgrade option i see the 3700 san diego proccy at 61 quid for the oem but retail is 81 why is there such a price difference is there any other differences you guys know of ie stepings or anything that you can shed some light on
bigjonnyauk said:
so if you had the choice would the 3700sd be better than the 3800 as the 3700 has a 1meg cache
yes, you can always overclock the 3700 but you can't replace the missing cache on the 3800. Both will probably overclock to about 2.8GHz anyway. ;)
got one of the oem 3700 sandys from here a few weeks ago the stepping on cpu-z says its :
family : F
ext family : F
model : 7
ext model: 27
stepping : 1
revision : SH-E4
hope that helps btw the artic cooling freezer 64 cooler is very nice and only costs 16 pounds :)
Got a 3700+ a few weeks ago and currently running 3gig stable at 1.55v and 28/48 idle/load temps.
Thats with the rather quiet arctic cooler as was. Much better ooption than the retail pack.
Who honestly uses a 3 year CPU warantee? I mean, it either works on day 1 or it's faulty and if you kill it overclocking your a numpty :D
