Building the System PT 2
Ok, back to the build!
After fixing the paint job on the Rad and having the final layers of clear coat applied to it, the Rad is ready to be installed.
The Rad was attached to the front of the case (after putting up some resistance), behind the two noise blocker fans.
I then used two 90 degree rotary fittings (one with a black spacer attached) to give me the angles I need to attach the tubes to the Rad.
This was the part I wasn't looking forward to. I knew that it would be a tight fit and awkward as heck to get the tube onto the fittings, and Boy was I right.
In the end I attached the tubes to the fittings first, then screwed the fittings into the Rad using my favourite tactic of tempered brute force and a pair of long nose pliers. Not elegant but it did the trick!
At this point I was going to fit the storage drive and GFX card but I couldn't wait to get the loop filled with some Blood Red fluid and get the painted panels back on to see what it would look like.... So I did!
With the tubing now complete I moved on and fitted my Samsung M.2 Drive and my Asus Strix 970 GFX card.
After adding a few cable ties here and there to organise my cables and an overnight leak test (which I'm pleased to say it passed) I arrived at the following...
None too shabby so far!
There is just one last detail that needs adding... The final piece of painting!
I'd ordered a stencil with the original plan of adding a graphic to the Monoblock. Due to various reasons (item didn't arrive for ages & I got bored waiting) that didn't happen.
However there was a plan B so here it is... Ladies & Gentlemen may I present the small but powerful Red Dragon!
I will say that the OCUK Painting Curse was in full flow whilst painting the Dragon (less said the better
) and in the end I had to rework the image so that the dragon was graded from light grey (smoke effect almost) into a dark red. Not what I originally intended i'll admit, but with 'necessity being the mother of all invention' (in other words I ran out of Red paint) I don't think it turned out too bad at all.
Now that it's all together I can start to work on seeing what I can get out of my GFX card with an OC & my CPU OC...
