- 11 Dec 2005
- Cheshire
OcUK Complete CPU & GPU Watercooling Bundle @ £233.98 inc VAT
The OcUK Complete CPU & GPU Watercooling Bundle is watercooling made easy, designed for the budding computer enthusiast who wants to maximise the performance of their system. All components are tested for compatibility so you don't have to worry about tubing sizes, pump flow rates and fluid choices. Here at OcUK we have done the hard work for you. Complete with a CPU block,GPU Block (optional), tubing, fittings, pump, reservoir, radiator and fluid all you have to do is select what colour fluid you desire.
- x1 EK Supreme i7 High FlowClear Top (775/1156/1366/AM3) CPU Water Block
- x1 XSPC DDC 18w Pro Pump/Reservoir
- x4 Masterkleer 7/16" Tubing - 1m (Total 4 meters)
- x8 1/2" Fitting G1/4" with O-Ring High Flow Stubby Connector - Black Nickel
- x8 XSPC Tubing Clip For 1/2" and 7/16" Hose
- x1 Fluid XP Extreme (Choice of colours)
- x1 Swiftech RX360 Triple Radiator
- x3 Sharkoon Silent Eagle 120mm 1000RPM fans(w/ screws)
- x1 Optional GPU full cover block of your choice for either ATI or Nvidia graphics solution
Includes free 6-page colour installation manual
Note - Please ensure the system case has the appropriate spacing and capacity to fit a full watercooling loop.
Only £233.98 inc VAT.
ORDER NOW
ORDER NOW
