** OcUK EXCLUSIVE: SUPERFLOWER POWER SUPPLIES NOW IN STOCK!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Over the past year we've had a lot of request to stock these units, they are amongst the highest quality power supply manufacturer out there, who always under-rate their own equipment.
For those of you who do not know, EVGA use SuperFlower as their OEM for their PSU's on their flagship items such as 1500W SuperNova.
This brand is really amongst the best, they make no short cuts, the quality is absolute top notch and even better THIS IS AN OcUK EXCLUSIVE BRAND:-
SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - White (NESF-013) @ £209.99 inc VAT
Leadex Platinum series PSU are 80+ Platinum certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features:-
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Platinum Certified, 91.07% 92.44% 90.47% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Specification:-
- Type: ATX
- Maximum Power: 1200W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable: Yes 100% modular cable design
- Input Voltage Full Ranage - 100V~240V
- Input Frequency Range 50 ± 3 Hz / 60 ± 3 Hz
- Output +3.3V@20A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- Protection OVP?OCP?OPP?SCP?UVP
- Dimension 200mm(L) x 150mm(W) x 86mm(H)
- Warranty: 5yr
Only £209.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - Black (NESF-012) @ £209.99 inc VAT
Features:-
Specification:-
- Type: ATX
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Warranty: 5yr
ORDER NOW
SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - White (NESF-011) @ £179.99 inc VAT
Features
- 80 PLUS ® Platinum Certified, 91.12% 92.53% 91.11% Efficiency At 20% 50% 100% Rated Load
Specification:-
- Type ATX
- Maximum Power 1000W
- Fans 1 x 14cm
- PFC Active
- +12V Rails 1
- Modular Cable Yes 100% modular cable design
- Warranty: 5yr
Only £179.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - Black (NESF-010) @ £179.99 inc VAT
Features
Specification:-
- Type ATX
- Fans 1 x 14cm
- PFC Active
- +12V Rails 1
- Warranty: 5yr
ORDER NOW
SuperFlower Leadex GOLD 1300W Fully Modular "80 Plus Gold" Power Supply - Black @ £179.99 inc VAT
Features:-
- 80 PLUS ® Gold Certified, 91.09% 91.75% 89.25% Efficiency At 20% 50% 100% Rated Load
Specification:-
- Type: ATX
- Maximum Power: 1300W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Output +3.3V@24A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- Warranty: 5yr
ORDER NOW
SuperFlower Leadex GOLD 1000W Fully Modular "80 Plus Gold" Power Supply - Black @ £149.99 inc VAT
Features:-
- 80 PLUS ® Gold Certified, 90.43% 92.03% 90.27% Efficiency At 20% 50% 100% Rated Load
Speciication:-
- Type: ATX
- Maximum Power: 1000W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Warranty: 5yr
Only £149.99 inc VAT.
ORDER NOW
SuperFlower Golden Silent 500W Fanless "80 Plus Platinum" Power Supply - Black @ £109.99 inc VAT
Features:-
- Supports all Intel and AMD multicore and its compatible Motherboards, ATX/BTX compliant.
- EPS 12V Ver2.92
- Fit in with EuP(Energy-using Products) instructions / U.S.A Energy Star standards: energy consumption during shut off status less than 1W
- Support NVIDIA (SLI)/ATI, high rank & high efficiency graphic card.
- PCI-E power plugs are setup in a 6+2 configuration for the latest graphic cards and Compatible with every brand.
- Passed 80 PLUS® Platinum Certification, on 20% 50% 100% loading, with 91.47% 92.88% 90.77% Transform Efficiency.
- Exclusive Patents (Taiwan, China, U.S.A patent applied)
- High Power Vertical Double Layer Main Transformer (U.S.A.Germany, Japan, Spainpatent applied) Taiwan Patent no:M381155;China Patent no: ZL2009 2 0273193.2)
- Extend Output Capacitance are used for higher stability and longer lasting.
- All Capacitor and Capacitance are made in Japan with higher stability and longer lasting
- Switches on/off test for more than 2000 times.
- All series are made of RoHS unleaded green material.
Only £109.99 inc VAT.
ORDER NOW
SuperFlower Golden Green 650W "80 Plus Gold" Power Supply @ £73.99 inc VAT
Features:-
- Supports all Intel and AMD Dual Core and Quad core and its compatible Motherboards, ATX/BTX compliant.
- Supports Intel Core i7-980X / Core i7 / Core i5 / Core 2 Quad / Core 2 Duo &AMD Phenom II X6 / Phenom II X4 / Phenom II X3 / Athlon 64 X2series chip set.
- EPS 12V Ver2.92
- Patent black color connector, easy plug-in design, safe and firmly attached.
- Patent 14cm LED Low Noise Fan, Great air flow for exceptional heat dissipation.
- Passed 80 PLUS® Gold Certification, on 20% 50% 100% loading, with 91.64% 92.88% 90.99% Transform Efficiency.
- Full Range APFC, support 100V~250V.
- Patent high power and low consumption transformer / Patent dual voltage circuit with intelligence thermal control system (Patent applying for U.S.A, Taiwan, Mainland China and other countries)
- Solid state Capacitance is used for longer lasting and higher reliability.
- Multiple safety certificates acquired.
- All series are made of RoSH unleaded green material.
Only £73.99 inc VAT.
ORDER NOW
SuperFlower Golden Green 550W "80 Plus Gold" Power Supply @ £59.99 inc VAT
Features:-
- EPS 12V Ver2.92
Only £59.99 inc VAT.
ORDER NOW
SuperFlower Golden Green 450W "80 Plus Gold" Power Supply - Black @ £53.99 inc VAT
Features:-
- EPS 12V Ver2.92
Only £53.99 inc VAT.
ORDER NOW
SuperFlower Golden Green 350W "80 Plus Gold" Power Supply - Black @ £44.99 inc VAT
Features:-
- EPS 12V Ver2.92
Only £44.99 inc VAT.
ORDER NOW
Here are some high-resolution photos of the Leadex White models, absolute works of art:-
Great power supplies which we are proud to be stocking and selling. :)
where is the Golden King? With whom is the warranty after 1st year? How long is warranty on Golden Greens?
Have EVGA stopped using FSP now then? Or do they use some and some?
No same set-up they have always had. Superflower make the 1000w and 1300w units. Etasis the 1500w unit. FSP the 650w and 750w units and HEC the 500w and 600w units.
The Superflower units are the only ones worth bothering with as the rest have had mediocre reviews.
There has been a potential problem with the Superflower EVGA units though and if anyone has one from before 1st October they should read this.
Doesn't look like it applies to Superflowers own units.
Some reviews of Superflower units linked to in the psu database.
Thanks for clearing that up. :)
Our versions are un-affected as fresh out the factory. :)
FSP make some quality units and shouldn't be overlooked.
Agreed 110%
The BeQuiet PowerZone series we sell are FSP inside with some tweaks/updates that BeQuiet specify as FSP allow changes/updates.
Were finding the Powerzones superb, very reliable and very quiet. :)
