OCUK KINETIC ZX - INTEL Z390 Changes
4 Apr 2015
So I called OC yesterday and I was recommended this system for my budget (around £1500) but I thought I’d run it past a few knowledgable people on here. I’ve just purchased a PG279Q 1440p 165hz Rog Swift (Gsync) and I’m looking for a system to compliment it nicely! So I can still spend a bit more of it’s going to be a worthwhile upgrade, how is this system just straight out the box? Or should I be looking at something completely different?
Some people will notice I’ve taken to this forum a few times asking similar questions but I’ve finally got around to buying the monitor so it’s full speed ahead now.
not to bad, board is Gigabyte which has best VRMs in each price band .
card only has 2 year warranty but im guessing as its been bought as part of the system, should fall under the full 3 year system warranty .
it would drive the screen just nicely .
ask them to change Kolink PSU to bequiet 600w that are on deal .
could drop down to 9600k and push RTX 2080 , give give you gtx 1080ti performance and push 15fps+ to take advantage of that high HZ monitor .
since gaming at 1440p, 9700 to 9600k should make to much different , spepcially if it can be clocked to 5ghz all cores
My basket at Overclockers UK:
  • 1 x OcUK Kinetic ZX - Intel Z390 Configurable Coffee Lake Refresh DDR4 Gaming PC = £1,590.95
    • Case:Kolink Levante Midi Tower Airflow Gaming Case - Black Tempered Glass
    • Processor:Intel Core i5-9600K 3.7GHz (Coffee Lake) Socket LGA1151 Processor - OEM
    • Memory:Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD416G30
    • Primary Drive:TeamGroup 480GB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive
    • Secondary Drive:Seagate BarraCuda 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - *System Stock*
    • Graphics Card:Inno3D GeForce RTX 2080 Twin X2 8192MB GDDR6 PCI-Express Graphics Card
    • WIFI:Unwanted
    • Operating System:Microsoft Windows 10 Home Advanced - Systems
    • Security Software:**Special Offer** Bullguard Internet Security - Anti-Virus and Security - 1 Year 3 PC
Total: £1,605.05 (includes shipping: £14.10)​
    • WIFI:Unwanted
That does seem like a strong move, so would you keep the rest the same though, case etc?
I’ll have to check out that gpu and cpu situation as soon as I finish work though but I feel pretty close to pulling the trigger!
seems 9700k is on offer for £100 , normally its about £150 to step up from 9600k to 9700k .
i think because of the cash off , its hard to do a build list and then have OCUK build it .
https://www.eteknix.com/gigabyte-geforce-rtx-2070-gaming-oc-white-review/5/
shows difference between gtx 1070/1080/2070/2080
fancied something small, ITX build. OCUK prob could build for £1500 all in :) normally charge £50-80
Total: £1,432.43 (includes shipping: £12.60)​
‘I think because of the cash off , its hard to do a build list and then have OCUK build it’ sorry, I don’t quite follow what you mean? Are you saying it’s hard to use their prebuilt and modify it or that it’s hard to pick all the parts and have it made?
Basically, I think he's saying that the system is such a good deal that you'll struggle to build it yourself for the same price/you might not be able to get OcUK to build you a custom quote for the same value (both of which are true)
Well that would make sense. The temptation to up my budget slightly for the Zotac 2080 is real though! I’m also a bit unsure of what pwm fans to get for the case but I’m sure I can’t leave it stock, it only has the one.
Wonder if Silent wings are still buy 3 for price of 2... Though they are £20 a pop and damn good !
Nah , was just a bundle deal of 3 fans by themselves . Was good because they are such expensive fans you were getting one free or 1/3 off .
Ahh I see, I think that’s gone now what would you do for cooling though? Add 3 140mm fans (2 intake and 1 exhaust and have the stock 120m on exhaust too?) and then do I need the fan regulator to control the fans and stop them spinning 100% all the time?
would personally just add two 140mm to the front and 120mm stock to the rear. keeps positive pressure high and forces air out of the case . Fans would plug into the motherboards headers and be controlled via its bios/software
Great help thanks a lot, that’s exactly what I done in the end too
