** OCUK NOISE DAMPENED CASES - FURTHER REDUCTIONS **
OcUK Staff
26 Nov 2014
Stoke
Whilst stocks last, we've further reduced the pricing on all pre-noise dampened cases, offering some superb products for even better prices!
Here are a few highlights :)
OcUK Tech Labs - Lian Li PC-X2000FN TYR Full Tower Case - Black - Noise Dampened Case @ £329.99 inc VAT
OcUK understand that our customers are looking to strive for that little extra over any other customers. We know that many of you strive for quiet computing, some of you spend literally hundreds of pounds on watercooling to reduce noise! Well we have listened (no pun intended, honest) and created a range of cases which are pre-installed with amazing high quality accoustic dampening pads, which are finished off with a leather style surface to provide that extra level of premium quality that should be given to you; our customers!
This Tech Labs case includes the standard case in its default format as produced by the manufacturer but our expert technicans have spent time dampening it with our Foam Dampening Kits!
- Default case; but noise insulated
- Pre-installed for your convience
- All foam dampening pads have a leather style finish surface
- Reduced accoustics
Was £409.99 Inc. VAT
Only £329.99 inc VAT.
ORDER NOW
OcUK Tech Labs - Silverstone FT03S Fortress - Silver - Noise Dampened Case @ £119.99 inc VAT
Was £139.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
OcUK Tech Labs - Anidees AI-6W Tower Case - White - Noise Dampened @ £94.99 inc VAT
Was £119.99 Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
OcUK Tech Labs - NZXT Phantom 820 Full Tower Case - Matt Black - Noise Dampened @ £199.99 inc VAT
Was £234.95 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
CHECK OUT THE FULL RANGE HERE
Do these come fully dampened or do we have to add/stick parts are self?
The last pre-dampened case i bought there was roughly 2-3 pieces of the sponge fitted an the multiple extra sheets i got i had to cut down to fit, i didn't have a problem doing it my self but i was under the impression that PRE-dampened meant it was all done ready.
Wish you guys would carry Fractal again, even if it was just the R5 range!! :(
No-one can touch them imo for a quiet performance range (except maybe Aerosol DS)
Thee are fully dampened throughout the range. The average case has around 7-8 separate pieces of noise dampened foam installed.
