Hi All,
I have been planning a build in an 800D for quite some time now, however due to several OcUK projects (Blade and Mammoth to name but a few) I haven't been able to make any progress until now that is.
The premise for my build is to do something with the 800D which hasn't been done before, or at least to my knowledge, yes this is going to be a challenge as the 800D has been cut and chopped by many a talented modders before me.
The Spec of the Machine will be as follows;
CPU: Intel 3770K - With IHS Removed and new TIM applied
Motherboard - Gigabyte G1 Sniper 3
Memory - Samsung Green 8GB 30Nm
PSU - XFX 750W
GFX - EVGA Classified 570 SLI
ODD - Slot Loading Blu-Ray optical
HDD - 128 Crucial C300 + 240GB SSD TBC
Case - Corsair 800D
Watercooling -
Pump - 2 x D5 Vario with Bitspower black sparkle mod kits & Bitspower dual D5 top in Acetal
Blocks - All Nickel Plexi EK Blocks
Rads - 2 x Black Ice SR1 480's + 1x Black Ice SR1 280
Tubing - Xspc 7/16 Black tubing
Fittings - Bitspower 7/16 compressions
Fluid - Mayhems Premixed UV Green
The first thing that I needed to do was to completely strip the 800D down, so the Hot swap bays were removed, then the lower HDD bays and floor were taken out. Finally the Mobo Tray and ODD drive bays were removed which left me with the bare shell of the case, as you can see below;
I will post some more up later once I have managed to get the photographs sorted.
PSU - XFX 750W
Case - Corsair 800D
Watercooling -
