I am going to use an EK Multi option advanced, not sure on which size yet though, if it will fit I want to use a 400mm res that will drop through the floor and output right next to the pumps, I need to do some measuring to see if it will fit the way I want it to as it might be too big
That sounds nice. Though you may be right about the 400mm being to long. Hopefully it will fit. If it is to long, could you not pull some stings with EK, and get them to cut and thread you a custom length tube?
Anymore from this Bicepo? I'm about to take on a similar mod but I'll be swapping out the entire back pane as well as motherboard tray so I can fit in an XL-ATX motherboard. So very very interested to see how your build turned out
