** OCUK TECH LABS AIO LIQUID COOLERS - PRICE SLASH **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Today I have slashed the prices of the Asetek based OcUK Tech Labs Cooling upgrade bundles and made some changes to make them even more attractive.
They now all come with a full size tube of Thermal Grizzly Hydronaut Thermal Paste as well as the OcUK Exclusive FQ121WC Fan.
The price drops are significant putting them in prime position to be the best performance/value AIO solutions available right now.
OcUK Tech Labs 120mm Extreme CPU Liquid Cooling Upgrade Bundle @ £59.88 inc VAT
Tame your CPU with the OcUK Tech Labs Extreme All In One CPU Liquid Cooling bundle
The entry level 120mm cooler is ideal for small space constraints or low heat output processors. The 240mm+ coolers are designed for more extreme applications and are ideal for cooling and overclocking high performance processors.
Paired with OcUK designed, watercooling radiator optimised fans, the Tech Labs All In One CPU Liquid Coolers provide superb value for money as well as incredible performance.
The AIO Liquid coolers in these system integration solutions are manufactured by industry leader; Asetek.
We ship every bundle with a tube of high performance Thermal Grizzly Hydronaut High Performance Thermal Paste - 1.5ml / 3.9g. This is the ideal thermal paste for ultimate performance with your upgrade.
Every Bundle has an option to include an OcUK Tech Labs recommended Fan Control unit that will ensure that you get the very best out of your Cooling Upgrade Bundle
Each CPU cooler is unbranded with a smart, stealth appearance. No flashing LEDs, no corporate logos or garish branding.
Installation is easy and all mounting hardware and instructions are included. Please ensure that your chassis is capable of accommodating the size of radiator you choose.
Cooler Features:
- Heat Exchanger Size: 120x120x49 mm
- Gen 4 Integrated Pump and Copper Cold Plate
- Double Thick 120mm Aluminum Heat Exchanger
- Designed for Single Fan Operation
- Factory Filled and Sealed, No Refilling Needed
- High Flexibility, Low Permeability Tubing
- 2 Year Warranty
Included in this bundle:
- Premium CPU Mounting Hardware
- Thermal Grizzly Hydronaut High Performance Thermal Paste - 1.5ml / 3.9g
- Asetek 120mm 570LC High Performance Compact AIO Liquid Cooling Solution
- OcUK FQ121WC Watercooling Radiator Fan
Was £66.73 Inc. VAT
Only £59.88 inc VAT.
ORDER NOW
OcUK Tech Labs 240mm Extreme CPU Liquid Cooling Upgrade Bundle @ £63.83 inc VAT
Cooler Features:
- Heat Exchanger Size: 120x120x30 mm
- 2400mm Aluminum Heat Exchanger
- Designed for Dual Fan Operation
- Requires 2 adjacent 120mm fan ports
- 2 Year Warranty
- Asetek 240mm 570LXL High Performance Compact AIO Liquid Cooling Solution
- 2X OcUK FQ121WC Watercooling Radiator Fan
Was £74.99 Inc. VAT
Only £63.83 inc VAT.
ORDER NOW
OcUK Tech Labs 240mm+ Extreme CPU Liquid Cooling Upgrade Bundle @ £66.83 inc VAT
Cooler Features:
- Heat Exchanger Size: 240x120x38 mm
- Double Long, Extra Thick 120mm Aluminum Radiator
- 2 Year Warranty
- Asetek 240mm 570LX High Performance Compact AIO Liquid Cooling Solution
Was £79.94 Inc. VAT
Only £66.83 inc VAT.
ORDER NOW
OcUK Tech Labs 360mm Extreme CPU Liquid Cooling Upgrade Bundle @ £96.78 inc VAT
Cooler Features:
- Heat Exchanger Size: 360x120x30 mm
- Thick 360mm Aluminum Heat Exchanger
- Designed for Triple Fan Operation
- 2 Year Warranty
- Asetek 360mm 591LX High Performance Extreme AIO Liquid Cooling Solution
- 3X OcUK FQ121WC Watercooling Radiator Fan
Was £109.94 Inc. VAT
Only £96.78 inc VAT.
ORDER NOW
Would the 360mm Extreme fit at the top of the upcoming Evolv ATX? Also, how quiet does this run? Is it a noisy pump/fan setup? I have a Nepton 240M in another system, so would be interesting to know how it compares to that. Would x3 fans make it much noisier than x2, or given there are more of them does it mean they run slower and therefore quieter?
does these support socket 1366? cant see it in the drop down menu on the product page
also apart from the 30mm to 38mm in the extreme and extreme+ 240mm models is there any benefit to having the extra 8mm? don't know too much about AIO and water cooling in general
I've actually looked at these in the last week, the only reason I still pondering is AFAIK there isn't any benchmarks of these coolers.
Price Difference
When you click through to purchase the prices are higher?
does it take some time to get from discounting to registering on the site?
The 240 is ideal for my next project
they are the same as the NZXT Krakens
Asetek are THE LARGEST OEM SUPPLIER OF AIO COOLERS ON THE PLANET
we are getting one to an independent reviewer to test.
we also offer a 14 day money back guarantee, so get one and if you arent 100% happy with it then send it back for a refund.
Great prices and I was looking to buy a 240mm cooler but the prices on the site aren't the same listed here?
yeah, it adds the price of the mounting kit to the product as you have to select it separately and there is no way of including it in the forum code generator we use.
sadly no 1366 support. it is a dead socket.
the extreme and extreme + difference is basically radiator thickness. it will provide slightly better cooling performance. all depends if you have the extra room in your case
that's a shame, was hoping to get one of these for my main system. will have to get a corsair one instead
thanks for the info though :)
These are great deals. Does the 360mm, 30mm thick radiator deliver better performance than the 240mm, 38mm thick one? It's difficult to find many good 360mm AIOs, should be a good fit for that phanteks luxe that I have my eye on.
The first 240mm rad option has interesting size specs. (120x120x30? :P )
Will wait on tests though, its between this and the Triton for me really.
do you want customisation, then get the triton
do you want stealth looks and good performance/£ then get the tech labs :)
Really tempted to get that 360 AIO although I'm not a fan of the blocks looks, Wish Corsair would hurry up and release a 360mm with the new GTX styling.
The 360mm version looks identical to the Thermaltake 3.0 Ultimate (minus the branding of course, and different fans I think)... which is also made by Asetek... so would reviews of that give an accurate idea as to how well the OCUK one will perform?
