Do you mean using a spread method rather than line or dot? How do you ensure covering entire IHS?The only downside I saw was on X99 you simply have to change the paste to cover entire IHS.
Here is the picture of the final build:
Closer picture in the spoiler tag.
I went with the 240 Extreem+ and is currently keeping my 5820k at 50C under AIDA64 stress test @ stock. I will get some overclocking results shortly.
Will the 240mm+ fit in a phanteks pro mid tower case?
^ Very good for dual AIO you running high LCC ? Uncore high and mems?? All this creates heat.
Did you change TIM also?? I really would not skimp on TIM for this cooler.
.does these support socket 1366? cant see it in the drop down menu on the product page
also apart from the 30mm to 38mm in the extreme and extreme+ 240mm models is there any benefit to having the extra 8mm? don't know too much about AIO and water cooling in general
yeah, it adds the price of the mounting kit to the product as you have to select it separately and there is no way of including it in the forum code generator we use.
we are waiting for the thermal grizzly.
tbh, if you want to cancel that off the order and just use the stock paste [which is actually very good anyway] then you can do so by contacting CS
