Thank-you for the time spent Rich it was very worthwhile for me. I hope these are viewed as a success and that you can do more. Here's a list of useful tips that were new to me (I was the one writing stuff down as you were talking):
Radiators:
- When speccing a radiator for silence, go for lower fins per inch. For performance go for higher fins per inch.
- A rule-of-thumb for sizing radiators is one 120mm section per component, plus one. So a single CPU would want 240mm rad, a CPU + GPU 360mm, a CPU + 2xGPU 480mm.
- Clean your radiator prior to use with deionised water to clear out the manufacturing gunk.
- Set up your radiators so that the fans take air out of the case.
- When air-dusting a radiator (after a bit of use) - the even-ness of the dust is a good indicator of your fan efficiency. More even = better distribution of cooling over the whole radiator. There will always a a "dead spot" for the centre of each fan.
Tubing and Fittings:
- 'O' rings are critical. Inspect each one carefully. The slightest nick or kink is going to be a leak waiting to happen. A small application of silicon gel from a hardware store (usually the bathrooms section) will help when fitting components.
- Warm the tubing before fitting (a hairdryer, heat gun or cup of hot water). It makes it a bit more pliable so you need less pressure to push it onto the fittings. Especially important when you're pushing down onto a motherboard for example !
- Do not overtighten. Finger tight until you feel resistance is enough.
- a Set of tube cutting shears is a wise investment to get clean edges perpendicular to the tubing.
Filling and Maintenance
- When filling your loop, only fill the res up to half to three-quarters before starting the pump up. This prevents pump kickback splashing the coolant around. Go slow and steady when filling the loop - there is no need to try and get all the coolant in a single pour.
- a 2 hour leak test is sufficient. Anything that's going to go wrong will have done by then.
- Consider strongly fitting a bleed valve to handle expansion. If you are going for hard-line tubing definitely fit one.
A big thank-you also to the Mayhems guys and the bench rig they brought along. I think its fair to say they are two nutters from yorkshire in a shed
They are also hugely knowledgeable, helpful and passionate about what they do. I see why the relationship is so strong.
I know there were issues with the twitch stream dropping out this morning. Hopefully there'll be enough in the two events for people to benefit.
And finally swag for those of a mercenary nature:
- A litre of Mayhems X1 clear courtesy the nutters from yorkshire
- An OC ginormous mouse mat
- An OC mug
- A gigabyte notepad
- A call of duty scarf
- A creative labs lanyard
- 3 Packs of haribo !
.. and the discount on WC products provided we use it quickly
