** OcUK UK Stockists of Mountain Mods Cases **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
It gives me great pleasure to announce the availability of the range of Mountain Mods Cases and accessories. These cases are regarded amongst the enthusiast community as being the ultimate case. The scope that a Mountain Mods case can offer your system is unbelievable, from small watercooled LAN boxes like the H2Go to the truly immense Extended Ascension, MM has it all.
There is literally no computer system that you can make that mountain mods does not have a case to accommodate. With standardised fan layouts, each case can be used with air cooling but excels when full of radiators.
For examples of what can be achieved with a Mountain Mods case, check out these superb build logs on our forums from our resident modding experts:
w3bbo - Project: Angel - Mountain Mods Ascension
mrdbristol - Project: Purple Rain - Mountain Mods U2 UFO
clone - Project: THE SHINY ONE - Mountain Mods Pinnacle 24
If you are building a serious system or simply want the best, this is it.
you will never need another computer case.
We will be stocking a range of Mountain Mods accessories to allow you to trick your case out.
Please note that delivery of each case is typically around 1 week, but during busy periods it can take longer to arrive to you.
All of these cases are available in Mirror Black Powder Coat, Black Wrinkle Powder Coat and Black Anodizing meaning you can chose the look that is perfect for your style
Check out the Full Range HERE to pick the finish that suits you!
Mountain Mods U2-UFO Case - Mirror Black Powder Coated (Original Top) @ £349.99 inc VAT
The U.S. manufacturer Mountain Mods is characterized by an extreme diversity of housing types. Rectangular or cube-shaped, lying flat or standing up there is a wealth of choice from them. Block just for the water cooling of this tower are perfect! Metal enclosures offer high stability, large-sized housing dimensions, many ventilation openings provide space for internal obstruct radiators. These are just some features which bring the Mountain mods case as the clear winner!
- The housing is not high, but broad, almost square, and offers plenty of space for a complete water cooling
- Room for up to nine 120mm fans (4 front L-size, three at the back and two in the top cover)
- Room for 1 x 360 1 x 240 and 4 x 120mm radiators. Of course this is entirely up to the individual design of the customer
- Through three Plexiglas windows (one on the left, the second enclosure wall on the right and also one on the cover) you have a clear insight into the housing interior, which is extremely interesting, especially for modders.
- Color: Mirror Black
- Material: Aluminum 5052
- Wall thickness: 1.65 to 3.25 mm
- Sealing: powder-coated
- Dimensions (L x W x H): 457 x 457mm
- Bays: 3.5 inch: 6 (by 2 more Haltermöglichketien expandable to 10)
- 5.25 inch: 5 (removable)
- Power supply openings: 2
- MB Mount: Removable
- Motherboard Support: ATX / ATX
- Fan Opening size: 120mm 9x
- Curb weight: about 6.8 kg
Included
- 1x Mountain Mods U2-UFO (Mirror Black Powder Coat) - Original Top
- 4x hard drive bracket
- 2x drive bracket
- Mounting screws and spacers for the motherboard
Note: The housing is not supplied in the assembled state. It is to be assembled by yourself. Delivery is typically around 1 week, but during busy periods it can take longer.
The hard drive mounts are mounted on the vent openings and the drive bays are mounted to the side walls of the designated holes. Other housing components can be ordered extra and are also mounted.
Only £349.99 inc VAT.
ORDER NOW
Mountain Mods U2-UFO Duality Case - Mirror Black Powder Coated (Original Top) @ £409.99 inc VAT
- You can mount two motherboards, each of which can be cooled with its own water-cooling circuit, because space is definitely enough there
- You can fit up to eight 120mm fans (6 forward in the front, three in a row, and two top of the lid). In addition, the housing provides the posterior wall of the housing, the ability to fit four 80mm fans.
- In the housing you can fit 2 x 360 and 2 x 120 Radiators. Of course this is entirely up to the individual design of the customer
- Through three Plexiglas windows (one large on the left, the second enclosure wall on the right and a slightly smaller additional housing on the cover) you have a very clear insight into the housing interior, which is extremely interesting, especially for modders.
- Color: black
- Sealing: Powder Coated
- Dimensions (L x W x H): 460 x 460 x 520mm
- Ventilation openings: 8 x 120mm
- Bays: 3.5 inches: expandable up to 15 & 5.25: 2 (removable)
- Power supply openings: 4
- MB brackets: 2x removed
- Fan Opening size: 120mm 8x & 4x 80mm
Included:
- 1x Mountain Mods U2-UFO Duality (Mirror Black Powder Coat) - Original Top
- 4x drive bracket
- 2x motherboard mounts
- 2x motherboard support bracket
Only £409.99 inc VAT.
ORDER NOW
Mountain Mods U2-UFO Horizon Case - Mirror Black (3 Big Window) @ £409.99 inc VAT
- The housing is not high, but more broadly - in other words, square - and provides enough space for a complete water cooling
- There can be up to seven 120mm fans fitted (3 x to 4 x on the front and the rear housing wall)
- The enclosure has space for 2 x 360 and 1 x 120mm radiators, or 7 x 120mm radiators.
- With three large Plexiglas window on the left, right and top housing wall, one has a clear insight into the housing interior, which is extremely interesting, especially for modders.
- Sealing: Powder Coater
- Dimensions (L x W x H): 460 x 460 x 550mm
- Ventilation openings: 7 x 120mm
- Bays: 3.5 inches: expandable up to 15 / 5.25: 2 (removable) / 5.25 inches: 6
- Motherboard Support: ATX / ATX / EATX
Included:
- 1x Mountain Mods U2-UFO Horizon Black Powder Coat - 3 Big Window
- 4x drive bracket
- 1x motherboard support
- 10x slot aperture
ORDER NOW
Mountain Mods Pinnacle 18 CYO Case - Mirror Black (Big Window Panel) @ £329.99 inc VAT
- The housing is very high and provides enough space for water cooling components
- There are 5 options are for mounting the fan. Three up front in the bottom half of the front and two at the rear of the enclosure wall
- This case offers a variety of options for mounting the radiators. The housing cover 240, a radiator or even a 360 with a waiver to be installed on one drive bay and also the possibility at the front in a vertical format, a 360 radiator place. In the rear of the enclosure wall can be installed 2 x 120 Radiators
- Through the Window window on the side is given a good insight into the inner life
- Sealing: Anodized
- Dimensions (L x W x H): 460 x 230 x 615mm
- Ventilation openings: 5x 120mm
- Bays: 3.5 inch: 1, expandable up to 3 / 5.25: 1 (removable) / 5.25 inches: 3
- Fan Opening Size: 6 x 120mm
- Empty weight: 4.5 kg
Inlcuded:
- 1x Pinnacle Mountain Mods 18 - CYO The Big Black with Window Panel
- 2x hard disk bracket
- 2x drive bracket
- 1x motherboard support bracket
Only £329.99 inc VAT.
ORDER NOW
Mountain Mods Pinnacle 24 CYO Case - Mirror Black (Big Window Panel) @ £334.99 inc VAT
-The housing is very high and very deep and provides plenty of space for water cooling components.
-There are 5 options are for mounting the fan. Three up front in the bottom half of the front and two back of the enclosure wall.
-This case offers a variety of options for mounting the radiators.
-The cover can be installed up to 480 radiators and is also the possibility at the front in a vertical format, a 360 radiator place. In the rear of the enclosure wall 2 x 120 Radiators can be installed or a 240 Radiator.
- Color: Mirror black
- Material: Brushed Aluminum 5052
- Dimensions (L x W x H): 610 x 230 x 615mm
- Ventilation openings: 5 x 120mm
Included:
- 1x Pinnacle Mountain Mods 24 - CYO The BEA Big Black with Window Panel
- 6x slot aperture
- 2x drive bracket
Only £334.99 inc VAT.
ORDER NOW
Mountain Mods H2GO Aluminum Cube Case - Mirror Black Powder Coat @ £254.99 inc VAT
- The housing is not high, but as the chassis is broad and almost square it has enough room for a complete water cooling setup
- Interior in the middle of the housing is a plexiglass plate mounted horizontal, which is intended as a mounting bracket for the motherboard
- It can be installed with up to six 120mm fans (3x 3x at the front and the rear housing wall), which are arranged as an L-shape
- The enclosure has space for 2x 240 and 2x 120 Radiators. It can also be mounted radiators 6 x 120
- Through three Plexiglass windows, one on the left housing wall and two on the cover you have a clear insight into the housing interior, especially for what most modders.
- Dimensions (L x W x H): 444 x 330 x 350mm
- Ventilation openings: 6x 120
- Bays: 3x 5.25 inch
- Power supply openings: 1
Included:
- 1x Mountain Mods H2Go - (Anodized Black) Aluminum Cube Computer Case
- 2x drive bracket
Only £254.99 inc VAT.
ORDER NOW
Mountain Mods Ascension CYO - Anodized Black (2 Big Windows) @ £489.98 inc VAT
- Large dimensions for plenty of space for a water cooling system
- Up to 16 120mm fans can be installed (9 in the front, 5 at the rear and 3 in the top)
- 3x 360mm and 2x120mm radiators can be installed. Of course individual implementation is always up to the customer
- Two large Plexi windows (one at the left and one at the right) case window give a clear view into the inside of the case for special modding effects
- The case offers space for two power supplies to fulfil even the most extreme power needs
- Colour: Black
- Material: Aluminium 5052
- Wall thickness: 1.65-3.25mm
- Coating: Anodized
- Dimensions (LxWxH): 475 x 475x 665mm
- Fan openings: 16x 120mm
- Drive bays: 3.5": Expandable to up to 4 / 5.25": 6 (removable)
- PSU slots: 2
- MB tray: Removable
- Mainboard compatibility: mATX/ATX/EATX
- Weight empty: approx. 13.05kg
Included:
- 1x Mountain Mods Ascension CYO Black Wrinkle with 2 Big Window Panel
- 4x HDD mount
- 4x Drive mount
- Mounting screws and spacers for the Mainboard
Only £489.98 inc VAT.
ORDER NOW
Mountain Mods Extended Ascension CYO - Mirror Black (2 Big Windows) @ £519.98 inc VAT
-Large dimensions for plenty of space for a water cooling system
-Up to 25 120mm fans can be installed (9 in the front, 4 at the rear and 12 in the top)
- In the case 3x480mm (top), 3x 360mm (front), 1x360mm and 1x 120mm (rear) radiators can be installed. Of course individual implementation is always up to the customer
- Coating: Powder coated
- Dimensions (LxWxH): 662 x 475x 670mm
- Fan openings: 25x 120mm
- PSU slots: 2
Included
- 1x Mountain Mods Extended Ascension CYO Black Wrinkle with 2 Big Window Panel
- 4x HDD mount
- 4x Drive mount
Only £519.98 inc VAT.
ORDER NOW
Mountain Mods Monticle 24 CYO Case - Mirror Black (Big Window) @ £269.99 inc VAT
- There are three possibilities are for mounting the fan. Two up front in the bottom half of the front and one at the rear of the enclosure wall
- This case offers a variety of options for mounting the radiators. The housing cover 240, a radiator or even a 360 with a waiver to be installed on one drive bay and is also the possibility at the front in a vertical format, a 360 radiator place. In the rear of the enclosure wall can be installed 2x 120 Radiators
- Through the window on the side is given a good insight into the inner life
- Colour: aluminum, black powder coated
- Dimensions (L x W x H): 661 x 228 x 463mm
- Ventilation openings: 3x 120
- Bays: 3.5 inch: 1, expandable up to 3 / 5.25 inches: 3
-Curb weight: 8.15 g
Included
- 1x Mountain Mods Monticle 24 - CYO Anodized Black with Big Window Panel
- 2x drive bracket
Only £269.99 inc VAT.
ORDER NOW
Guys, more importantly, are you going to stock/sell all the accessories for these cases like is listed on mountainmods main site?
Also consider things like 3x120 fan grills/filters etc. All these are needed for these cases.
I think there should be a sub catagory in the Cases/Mountain Mods/Accessories section, make it easy to find.
Excellent stock choice. I have used Mountain Mods Cases in builds and the quality is second to none. Delivery costs were a major factor in price though so nice to see a UK stockist. Had you launched earlier i might have bought one of these instead of my new Caselabs case.
Well done OcUK
Good to know Overclockers will be stocking Mountain Mods cases finally no more import duty taxes nice move guys, any plans on stocking official MM accessories ? :)
Prices a bit too much than the other UK stockist, but I'm guessing they're not stocking them any more given your 'only available' tag.
dollar rate has a lot to do with it.
prices are more than reasonable for what they are.
try and import one and see how much you save getting it from us. [consider tax on top of the case value + shipping from the USA]
they are not expensive at all considering how much use you can get out of one. they are fully modular so allow for changes in the future should new motherboard designs [such as classified X4 or SR-2] come out.
like I say, this is a case for life that will last many many upgrades.
they are not expensive at all given that they cost the same as a high end GPU and will last a lot longer.
