OcUK Ultima Mammoth - New System Project
OcUK Staff
8 Oct 2009
OcUK HQ
Myself, Nathwraith and RJK are working on something a little special for our system range, it's going to be epic that's all I am saying at this moment in time.
Check back for updates about the Mammoth new system project.
The case that we are using for the build is one of these;
The Internals of the case look like this from the factory, however the aren't going to remain this way for long :D
And from the front with the front panel removed
The First Job on the very long list of things is to strip the case of all the things that we need out of the way for all the watercooling that we are going to fit into the case.
Here is a picture of the case after it has been gutted
Once we had done this we can get a real feel for the space that we have to work with and what we can fit in.
So we firstly fitted the double 140MM radiator in the roof of the case which is a perfect fit.
Next we started to look at mounting the 360's in the front, for this we are using the EK Rad mounts which are very versatile.
Now that we have these in place we started to mount the first rad and secure this top and bottom.
Then all we did was repeat this method for the second rad that would will be mounted behind the first.
And now some more pics now that the rads are all in.
Lots of Watercooling! :D
Sorry to be a tease! I will post some pictures tonight of the case that we are using and then start a build log for you guys. Of course we will value you opinions on what else we can do!
is it a TJ07?
give free ones to the first five people to post in this thread?
You Wish,
No its not a TJ07 but it does have 3 rads in it!
Unfortunately we cant give these away for free but they will be available for purchase! :D
That would live up to the epicness that the hype is creating...
Then again, if it is a TJ11, it'll fall short of Kier's amazing-looking carbon build ;)
well what other case than the tj07 can fit three internal rads?
also it's very hard to compete with kier on any of the cases that he has modded :p
Its not made by Silverstone as nice as the TJ11 is, we wanted to use something that hasn't been done before, or at least very few!
Check the op for update
fractal design xl?
*shudders*
With the amount of work it took to get my triple 140 in an XL...no, we won't be building in those any time soon. You can fit 3 rads in them but only just, plus you then have no room for anything else.
(insert obligatory "Fractals get decimated in transit" comment here)
