- 31 May 2012
Hi again, related to a previous thread here:
http://forums.overclockers.co.uk/showthread.php?t=18414463
But with a different question now
I'm interested in purchasing a watercooled system and would like to know what you guys think of its watercooling components and case. This will probably be quite a long post, my apologies if it sends you to sleep!
What are your thoughts with regards to the Lian Li PC-Z70 Diamond Series Full Tower Case compared to the Silverstone TemJin TJ11 Full Tower Gaming Case? Is one significantly better than the other? The reason I ask is because I'm looking at this system, and it uses the Lian Li case:
http://www.overclockers.co.uk/showproduct.php?prodid=FS-185-OE&groupid=2180&catid=2203&subcat=
It has the following watercooling Specs:
WC-080-EK EK Supreme HF CPU Waterblock - Full Nickel
WC-012-BX Black Ice GT Stealth 360 Radiator (x2)
WC-093-EK EK UNI Holder 50-70 - Black (x4)
WC-003-BX Hardware Labs Black ICE Radiator GT Stealth 120
WC-178-EK EK-FC680 GTX Full Cover Waterblock - Nickel Plexi (x4)
WC-190-EK EK-FC Link GeForce (x4)
WC-200-EK EK-FC Bridge QUAD Parallel
WC-137-EK EK-PSC Adapter Rotary 45° G1/4 Black (x3)
WC-138-EK EK-PSC Adapter Rotary 90° G1/4 Black (x3)
WC-298-OK OcUK 1/2" G1/4 - FatBoy Style - Black Nickel - Barb Fitting (x14)
WC-011-AQ Aqua Computer Aquaero 5 LT USB Fan-Controller
CM-087-BX BitFenix Alchemy 3pin Fan extension 90cm - Black
CM-093-BX BitFenix Alchemy 3pin Fan extension 90cm - Red
CB-000-BX BitFenix Alchemy 24pin ATX extension 30cm - Black
CB-001-BX BitFenix Alchemy 8pin EPS extension 45cm - Black
CB-003-BX BitFenix Alchemy 6pin PCI-E extension 45cm - Black (x8)
CM-024-BX BitFenix Alchemy Molex to 4 x SATA power extension - Red
WC-002-MH Mayhems X1 UV Red Premixed Watercooling Fluid 1L
WC-008-EK EK Multioption Reservoir X2 250 Advanced
What do you think of these specs? Are they top quality components? I'd like my system to be powerful and quiet. Are these components of a high enough quality to ensure that it is a silent system? (within reason)
Would any of you use different components?
It looks like they use barb fittings, but I thought compression fittings were better?
I'd greatly appreciate any help with my decision, thanks guys
