OCUK's money saving tips
22 Oct 2008
Lisburn
Lets put Martin and his ilk out of business....what's your money saving tips?
Save a fortune on laundry bills. Give your dirty shirts to Oxfam. They will wash and iron them and you can buy them back for fifty pence.
or
Take one grape to the till. It won't register on the low-tech, insensitive scales so you will get it for free. Repeat this procedure 100 times or so and you have yourself a free bunch of grapes.
Don't buy expensive 'ribbed' condoms, just buy an ordinary one and slip a handful of frozen peas inside it before you put it on.
I find the best way to get two bottles of washing-up liquid for the price of one is by putting one in your shopping trolley and the other in your coat pocket.
They will only steam the garment before putting it out on the shop floor and that's only to release any creases. They won't wash any of the clothes. If a garment is dirty then it's sent to be recycled.
Best tip i can give is only Buy things off the End of the aisles & Never buy anything that is down the aisle.
Go to 3 supermarkets using the above & you'll have all you need for about half the price.
Buying loss leaders actually means the supermarket is picking up part of your bill. :D + :cool:
You don't need a whole carpet just cut some carpet to fit as slippers.
Internet charges too high for you? WEP has been cracked, turn on your wireless and look for vulnerable networks to break into!
or
I have a good one for the people who overspead on PC componants when they don't need the power, except a show off boat.
DO NOT SPEND ON COMPONENTS YOU DON'T NEED.​
