http://www.pcr-online.biz/news/read...-shoots-light-beams-into-your-eyeballs/032194
Makers of a new gaming headset called the Virtual Retinal Display say the specs are more realistic than the Oculus Rift.
Unlike the Oculus Rift, which features an LCD panel, these goggles project light directly into each eye using an array of two million micromirrors.
The brain interprets the signal as an 80-inch panel viewed from eight feet away.
Because Retinal projection requires precise alignment, Avegant’s headset has a frame that expands to accommodate different face widths. It also has high-quality optical elements that can be individually adjusted, giving it that ‘optician’s glasses’ feel.
The Virtual Retinal Display offers a separate 1,280x768-pixel resolution image for each eye – twice the effective resolution of the current Oculus Rift developer kits.
Consumer prototypes are expected at CES 2014 and the device should be making its way to a crowdfunding site within the next few months.
Not keen on the thought of beams going straight in your eyes like but the resolution sounds interesting enough and its per eye not 720p split like the rift atm. Still, probs far too much either rift or this thing for myself but which would you go for?
