Oculus rift remove minimum spec warning?
5 Mar 2007
Macclesfield
Hello,
Has anyone successfully removed the oculus rift remove minimum spec warning? (recently) I've got two rifts one meets the spec and the other - CPU, AMD 8320 is the problem, although overclocked to 8350 speed. It runs all the games I play fine but the warning (on the home screen) is very annoying...
Cheers,
Thanks for the suggestion but I didn't think the tray tool worked anymore?
(I'll give it a go if I get time later)
I get that message as well but i think its down to my built in unsupported USB3 ports than the actual cpu/gpu etc.
its bloody annoying as i have a dedicated usb3 card for the Rift itself, those ports just sit there.
