Now on 2.11 firmware & have reinstalled Win 7 after Secure erase & cleared cmos.
Previously with a WD Black hdd I had two overclocks:
1. Q9550 default 2.83GHz to 3.4 100% stable
2. 3.782 stable except due to user error & on reboot after win/program updates. since dropped FSB from 445 to 442 = 3.757GHz with SSD
SSD is stable on 1. but 2 leads to BSOD's within minutes [ would run for several days with 2.09].
ASUS P5Q-E mobo. Have upped volts on CPU, CPU Pll, NB, NB GTL without effect.
Use a Startech PCIE card & have increased SB & PCIE Sata volts by 1 step from default. Tried SB from 1.2 to 1.3 & PC froze.
Tried connecting to SATA 2 port on mobo & BSODed on 2. just the same, so its not the PCIE card.
OcUK have said having an SSD shouldn't affect overclock, so is the drive duff?
The BSOD's don't happen when the drive is moving large amounts of data. Within 5-10 minutes of booting. BOINC running on hdd
At lot are Hal.dll + ntoskml.exe errors but others before reinstall weren't.
I have tried taking the CPU GTL 0/2 & 1/3 of auto but can't seem to find a setting that is stable.
Any advise welxomed
Any advise welxomed
Thanks for the answer.
but at least that is stable & cooler.
