OCZ Failure, Where do I stand
1 May 2003
I have had my OCZ memory for about 10 months and it has failed on me. I am in the proccess of RMA'ing it back to OCZ, the trouble is the memory I purchased is now EOL (end of Life). This memory cost me about £240 for 1GB of OCZ EL DDR PC-5000 Dual Channel Platinum DFI nF4 Special. Where do I stand now as they will find that the memory is at fault, what are my choices :confused:
I believe they always keep some stock back to honour RMA's, well most companies do at least. Otherwise they will probably send you something else, afaik they must give at least a 1 year warranty on all electrical goods sold in the UK.
Could you not ask them for your money back? Because they won't have RAM as good as that anymore.
I'v had a faulty product in the past (broke after 5 months) and when i sent it back to the retailer i asked for a refund, which they did.
That may just be good Customer service though
Would I be better off sending it back to the retailer, than the manafacturer? I am wondering what will happen as the price I paid for 1GB then, you can get 2GB for the same price :confused:
I'd assume if they didn't have any of that particular product line left they'd return something at least as good or even better. I RMA'd a 420W PSU to them and got back the 600W version. Email them or post on their support forums and I'm sure they'll be quick with an answer.
Well for one you had it 10 months so I highly doubt you will get your money back, and secondly products that have a *limited* lifetime support are sometimes not covered once the product is EOL. . .
OCZ will probably take care of you though and if they don't have anymore of the same memory they may offer you something different.
Skiddley said:
Do it via OCZ, they are fantastic at this sort of thing - fed-ex'd me some out really quickly when i had problems.
Just to second this, OCZ Customer Service and particularly their RMA dept is awesome, and I don't use that word lightly.
I've RMA'd memory back to them before that didn't overclock as much as I wanted it to, no other reason... it ran at its rated speed fine, but not much higher. How mad is that - a company that will replace memory which works *to specification* 100% perfectly but that the customer isn't completely happy with? I actually felt bad for even asking - but they were great.
Seriously, I wouldn't buy any other brand memory after my 100% positive experiences with OCZ customer support.
Big.Wayne said:
well thats good news! I think it cost me about £12.00 to send my set of OCZ over to sunny LA! (International signed for).
Which company did you use for this mate. I contacted Fed-Ex & UPS and they both wanted £54 to deliver to Sunnydale :eek:
Hi,
it's a bog standard service offered by the royal mail, similar to services like recorded delivery and special delivery, available from the post office counter I think?
Big.Wayne said:
Hi,
Cheers, I'll look into it later on today. Still at work at the moment, as I'll need to send it off in the next 48 hours :)
